[mapguide-users] RE: RE: King.Oracle 0.3.3
Andy Morsell amorsell at spatialgis.com
Wed Oct 25 23:47:36 EDT 2006
You should be OK with your Oracle Spatial data and the King provider.  As
long as you have SDO geometry and Oracle spatial indexes, it should work.
Your ESRI style metadata won't be read, however.
Andy
-----Original Message-----
Sent: Wednesday, October 25, 2006 8:17 PM
Subject: RE: [mapguide-users] RE: RE: King.Oracle 0.3.3
I don't have anything but a 6.5 install so I'm out of the loop here. But, I
have esri data in my oracle SDO with esri style metadata does that mean I
couldn't use the king oracle provider?
Yes, I agree.
For metadata we can use already existing Autodesk FDO metadata, ( and that
is something I will support) and yes I am trying to avoid metadata as long
as possible.
Haris
Sent: Wednesday, October 25, 2006 8:04 PM
Subject: [mapguide-users] RE: RE: King.Oracle 0.3.3
Both of those things are true, but PK constraints and spatial index types
may be defined on tables, and not on the views on top of the tables. When
your dealing with views, you don't really know what is going on underneath.
While it *may* be possible to do some reverse-engineering and figure some
things out automatically, i doubt the work is worth the effort. Whatever
format of metadata you use is probably OK, as long as it can be easily
accessed programatically.
I would just point out that any metadata specified should be thought of as
'overrides' in the sense that they are not required. People who just wanted
to use tables (with well defined PKs and what not) could just use the
provider as-is.
haris kurtagic wrote:
 > Hi Joel,
 > Thank you for your comments.
 > Regarding geometry type, basically you can do it when defining spatial
 > index type in Oracle. This could also improve performance especially  >
on points Also key columns can be defined via primary key ( unique  >
wouldn't be ok because I think fdo wouldn't recognise null as a key )  >
Yes, In principle I don't like of putting a lot of metadata inside db,
 > but when is necessary
 > Haris
 > From: Joel Carranza [mailto:jec at gatekeeper.com]  > Sent: Wednesday,
October 25, 2006 7:42 PM  > To: users at mapguide.osgeo.org  > Subject:
[mapguide-users] RE: King.Oracle 0.3.3  >  >  > Its seems to me that
eventually you will have to rely on user supplied
 > metadata to solve this problem. For each table or view, a user would  >
be able to specify a key column and also maybe what type of geometry  >
(point,line, poly, mixed, etc...) is in the table. Specifying a type  > of
geometry would be nice, so that layers created from feature classes
 > are correctly displayed in legend. Eventually, you will probably need  >
to allow for other types of metadata as well. This info could be  > stored
in a table within Oracle or in a config file internal to the  > provider.
I'm not sure that it matters.
 > Joel
 >> Hi Joel,
 >> Regarding selecting, I tested it again and I am able to select layers
 >> wich comes from tables with primary keys.
 >> Right now primary key is only way to tell provider to use that column
 >> as identity.
 >> Any sugestions are welcome.
 >> I should do something for views also.
 >> Note:
 >>  It seems there is an issue in viewer regarding selecting:
 >> If you have a large scale layer and then zoom in much smaller and  >>
then  >  >> you click on feature, mg will send wrong coordinates for
selecting on
 >> that click hence tooltip will work, it send different coordinates to  >>
provider for tooltip and click on.
 >> If you take that same layer and put in the map, and give map a  >>
smaller  >  >> extents, click on and tooltip works.
 >> Haris
 >> From: Joel Carranza [mailto:jec at gatekeeper.com]  >> Sent: Tuesday,
October 24, 2006 8:05 PM  >> To: users at mapguide.osgeo.org  >> Subject: Re:
[mapguide-users] King.Oracle 0.3.3  >>  >>  >> Fantastic! Talk about agile
development. My views showed up and are  >> now displaying. I'm having some
performance problems, but those could
 >> easily be my fault. Too much data on too small a machine. Still, I  >>
have a gig of ram on my machine, and while I was browsing a map, I  >>
completely filled it up. I don't think that should happen?
 >> Weirdest thing I have found is that none of my map features in DWF or
 >> AJAX are selectable, even though I set them up to be in map  >>
definition  >>  >>  >> haris kurtagic wrote:
 >>> Hi,
 >>> newer version of King.Oracle 0.3.3 provider:
 >>> *	Support for Spatial Views
 >>> 	It will display views based on spatial tables. Views needs to be
 >>> added into sdo_geom_metadata for provider to find them.
 >>> Get it here: www.sl-king.com/fdooracle  >>>  >>> Haris  >>>  >>>  >>>
>>>  >>  >> --  >> View this message in context:
 >> http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6978386
 >> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
 >> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
 >> For additional commands, e-mail: users-help at mapguide.osgeo.org  >>  >>
>>  >  > --  > View this message in context:
 > http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6996820
 > For additional commands, e-mail: users-help at mapguide.osgeo.org  >  >  >
http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6997191
_________________________________________________________________
Use your PC to make calls at very low rates
https://voiceoam.pcs.v2s.live.com/partnerredirect.aspx
More information about the Mapguide-users mailing list
