[mapguide-users] vector editing
Paul Spencer pspencer at dmsolutions.ca
Sat Oct 28 14:10:34 EDT 2006
you lost me ... what is "command-line" COGO?
Cheers
Paul
On 28-Oct-06, at 1:40 PM, Jason Birch wrote:
> This digitising stuff sounds really cool Paul.
> When are you going to be adding "command-line" COGO capabilities to
> this? :)
> Jason
> ________________________________
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Sat 2006-10-28 10:26 AM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] vector editing
> Shailesh,
> I will try to put together a description of the tools and their
> capabilities soon.  In the mean time, to satisfy curiosity, here is a
> quick outline:
> The editing tools are being built on top of an application framework
> we are building for MapGuide OS/Enterprise.  This framework is
> tentatively known as Fusion or MapGuide Fusion.  It uses a modified
> version of a weblayout resource to define the commands, toolbars, and
> context menus for an application.  There are some changes to the
> schema of the weblayout that makes it incompatible with the existing
> ajax viewer and with Studio, so currently the weblayout has to be
> created by hand.
> MapGuide Fusion uses an HTML page and a single javascript include
> (fusion.js :)) to parse the HTML page and insert functionality based
> on the ID of HTML elements and associated Commands from the
> weblayout.  This allows much more flexibility when designing an
> application (you can put anything anywhere), and separates code from
> presentation quite nicely.  It also compartmentalizes the code into
> separate pieces of functionality that interoperate in a standard way
> to make code easier to write and maintain.
> This toolkit is brand new, but builds on the experience DM Solutions
> Group has with building similar toolkits around MapServer.
> The toolkit itself will likely be an open source project, hopefully
> merging into the MapGuide OS project and potentially replacing the
> existing weblayout/ajax viewer component (although there is a lot to
> be done and to discuss before this becomes a possibility).
> The editing tools are part of something we are tentatively calling a
> Light-Weight Edit capability (LWE).  They would be available as an
> extension to MapGuide Fusion and would include a simple editing
> application plus the actual widgets that would allow inserting
> editing into existing applications built on MapGuide Fusion.
> The editing capabilities include both digitizing (creating new
> features) and editing existing features in a web-based environment.
> The tools are seamlessly cross-browser compliant in Internet Explorer
> 6/7, Firefox 1.5/2 and Safari 2.  I haven't tested in Opera, but I
> think it will work there too.
> The tools generally work by creating shadow copies of feature sources
> to prevent accidents.  There is an undo and automatic recovery
> capability because deletes and edits are stored in the Library
> repository rather than the Session - if you close your browser, you
> have an opportunity to restore when you next connect.
> The tools work with the currently selected layer (managed by a layer
> control), and allow you to have multiple edits on multiple layers
> without saving.  For layers that have a single geometric type, the
> tool automatically creates the appropriate type of geometry.  For
> layers that have multiple types, the user is prompted to select from
> the available types.
> There is a commit tool that takes existing edits and merges them back
> into the original feature source.
> Because we use the Feature Service API, the editing capability is
> independent of the provider used with the feature source ... but it
> does have to be a vector feature source of course!
> For editing capabilities, we have the same basic node/segment editing
> capabilities that you would find in most vector editing packages:
> * digitize/edit points, lines and polygons
> * select a node and drag to move
> * select a line segment (two nodes) and drag to move
> * shift-select to add nodes to the selection
> * delete nodes (del key)
> * insert new nodes
> and probably a few other features that I've forgotten.
> We are also building an attribute editing grid so that you can edit
> the attributes of any selected feature (and newly created ones too).
> Availability: well, much of this is actually already done.  But it
> needs a few finishing bits and pieces, and substantial testing.  My
> current plan is to have this ready for the new year.
> Um ... seems like I've written a pretty good description ;)
> Cheers
> Paul
> On 28-Oct-06, at 4:24 AM, shailesh wrote:
>> I don't think even mapguide Enterprise has any of these capabilites
>> either. Any one at autodesk following up this please confirm.
>> Paul can you publish / post the capabilities of the tool/s DM is
>> developing ?
>> Eager to understand upto what extent can we go, while proposing
>> architecture to our clients using mapguide applications and have
>> very few requirements in terms of editing maps.
>> -Regards
>> Shailesh
>> ----- Original Message -----
>> From: Paul Spencer <pspencer at dmsolutions.ca>
>> To: <users at mapguide.osgeo.org>
>> Cc:
>> Date: Saturday, October 28 2006 12:10 AM
>> Chris,
>> it is possible, but there are currently no tools in the open source
>> package that allow you access to this functionality.
>> MapGuide Enterprise may contain some of this functionality, but I'm
>> not sure.
>> DM Solutions Group is working on building some of these types of
>> tools as a commercial capability on top of MapGuide OS/Enterprise.
>> Contact me directly if you are interested in this.
>> Cheers
>> Paul
>> On 27-Oct-06, at 11:46 AM, Chris Stewart wrote:
>>> Hello
>>> Could someone tell me if it is currently possible to create a web
>>> application that enables a client to remotely edit vector data for
>>> their
>>> own purposes - as opposed to just being able to view data, zoom
>> in and
>>> out and create buffers - using MapGuide Open Source, together with
>>> either MapGuide Web Studio or Autodesk MapGuide Studio.
>>> Many thanks
>>> Chris
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Chief Technology Officer |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For
> <winmail.dat>
More information about the Mapguide-users mailing list
