[mapguide-users] perfomance test
Haris Kurtagic haris at sl-king.com
Sun Oct 29 17:18:21 EST 2006
Yes, I've  tried envelope but I wanted to try more complicated query (to
use primary and secondary filter in Oracle) and also couldn't see huge
difference on this small set.
If I understood you correctly you mean sdf provider is not loosing time
in converting to FGF format ?
I agree on that but that is format use in MG, so that is one + for sdf
Haris
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Sunday, October 29, 2006 11:13 PM
To: users at mapguide.osgeo.org; users at mapguide.osgeo.org
Subject: RE: [mapguide-users] perfomance test
Did you try an EnvelopeIntersects filter? That one is by far the most
common one, rather than Intersects.
It is not surprising that SDF is fastest by far... The SDF provider does
not add any intelligence to the data and stores everything in FGF format
so you are basically getting back a pointer into database memory when
you ask for the geometry.
Traian
	-----Original Message-----
	Sent: Sun 10/29/2006 4:57 PM
	Cc:
	Subject: [mapguide-users] perfomance test
	After some discussion's here on this list I got interested in
comparing different data source and fdo providers.
	So, I have used an test application written as pure FDO client.
	I have run test again sdf, shp , 10gr2 and xe, using osgeo sdf,
shp and king.oracle provider.
	Data used in test is Sheboygan_Parcels.sdf from MG unittest
data.
	Before I wrote the results I would like to make strong point
that this could be altogether false results, I don't know anything about
writing true fair tests.
	As my lawyer told me I should put in here : whatever is written
is not promise, could be wrong and ..... :)
	17565 features read in case 1,2, 6681 fetaures in 3,4
	results are in seconds
	Test case 1: No geometry filter, Fetch all attributes
	SDF        0.937
	SHP        8.531
	10GR2    18.172
	XE            18.500
	Test case 2: No geometry filter, Fetch Geometry and Identity
	SDF        0.031
	SHP        0.109
	10GR2    1.938
	XE           1.735
	Test Case 3:  Geometry Filter, Fetch all attributes
	SDF        0.390
	SHP        3.391
	10GR2     6.906
	XE            6.218
	Test Case 4:  Geometry Filter, Fetch Geometry and Identity
	SDF        0.031
	SHP        0.140
	10GR2     0.891
	XE           0.797
	Geometry Filter was: SHPGEOM INTERSECTS GeomFromText('POLYGON
((-87.72 44, -86 44, -86 42, -87.72 42, -87.72 44))')
	and for SDF and King.Oracle it returns same number of features
6683 which is good
	shape provider returned : 6681 ?
	Original SDF file was copied to Oracle using that same tool, I
call it Fdo2Sdo.
	Oracle 10GR2 is running on my same desktop in virtual machine
and XE on localhost.
	My Remarks:
	SDF is really fast and highly optimized for this kind of
queries. Test Case 4 would be the most used case in real word app. and
differences there are smallest.
	I think if you add overhead of MG and other overheads than
influence would be even smaller.
	I think these tests are very unfavorable to Oracle.
	This test is run with very small data set (just 17565 polygons),
I believe much larger data sets would be more preferable to Oracle.
	I also couldn't run test with ordering or grouping (sdf,shp
don't support it). I run this test immediately after installing Oracle,
not using any spatial index optimization
	and also provider is not highly optimized as could be.
	Here I am comparing file system to database ( it is little
unusual ), It would make more sense to test against other db.
	I will make this tool freely available very soon, so you will be
able to run test by your self's, and also it would be nice to test other
data sources and providers.
	I hope that someone will find this tests useful.
	I will welcome every comment on this and if I made this tests
wrongly please do tell me.
	Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061029/d7ad46cd/attachment.html
More information about the Mapguide-users mailing list
