[mapguide-users] Feature Joins
Campbell, Keith A keith.campbell at atkinsglobal.com
Fri Sep 8 04:37:41 EDT 2006
Thanks Kenneth.
I will want the users to be able to select objects from the layer and
read the joined feature values, so I do have a problem.
Keith
From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: 08 September 2006 09:20
Subject: Re: [mapguide-users] Feature Joins
The short answer is yes.
I have no problems displaying maps/porperties when using ODBC for
secondary sources.
But, I have written a bit with Ronnie Louie form Autodesk, about
selections on such featuresets.
Ronnie can select from such a Join using my data, but I can't.
So unless, you want to select objects from the layer and read joined
feature values using the API, you should be fine.
The error message I get is:
OSGeo.MapGuide.MgFdoException: An exception occurred in FDO component.
no string resource for id <1019> -
MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_tux_area\mgdev\server\src\services\feature\FeatureServiceHandle
r.cpp
- MgOpSelectFeatures.Execute line 115 file
c:\build_tux_area\mgdev\server\src\services\feature\OpSelectFeatures.cpp
- MgServerSelectFeatures.SelectFeatures line 217 file
c:\build_tux_area\mgdev\server\src\services\feature\ServerSelectFeatures
.cpp
- MgServerSelectFeatures.JoinFeatures line 1008 file
.cpp
Campbell, Keith A skrev:
	All,
	Can an ODBC Feature Source be used in a Feature Join (as the
secondary feature)?
	Thanks,
	Keith
	This email and any attached files are confidential and copyright
protected. If you are not the addressee, any dissemination of this
communication is strictly prohibited. Unless otherwise expressly agreed
in writing, nothing stated in this communication shall be legally
binding.
This message has been scanned for viruses by MailControl
<http://bluepages.wsatkins.co.uk/?4318150>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060908/db544a0d/attachment.html
More information about the Mapguide-users mailing list
