[mapguide-users] Feature Joins
Campbell, Keith A keith.campbell at atkinsglobal.com
Fri Sep 8 04:49:47 EDT 2006
OK, thanks. I'll try and get my feature joins to work.
From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: 08 September 2006 09:45
Subject: Re: [mapguide-users] Feature Joins
The values display fine in the selection pane, if they are selected from
the client side.
It only occurs when selecting from the data source thorugh the server
side API.
Campbell, Keith A skrev:
	Thanks Kenneth.
	I will want the users to be able to select objects from the
layer and read the joined feature values, so I do have a problem.
	Keith
	Sent: 08 September 2006 09:20
	The short answer is yes.
	I have no problems displaying maps/porperties when using ODBC
for secondary sources.
	But, I have written a bit with Ronnie Louie form Autodesk, about
selections on such featuresets.
	Ronnie can select from such a Join using my data, but I can't.
	So unless, you want to select objects from the layer and read
joined feature values using the API, you should be fine.
	The error message I get is:
	OSGeo.MapGuide.MgFdoException: An exception occurred in FDO
component.
	no string resource for id <1019> -
	MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_tux_area\mgdev\server\src\services\feature\FeatureServiceHandle
r.cpp
	- MgOpSelectFeatures.Execute line 115 file
c:\build_tux_area\mgdev\server\src\services\feature\OpSelectFeatures.cpp
	- MgServerSelectFeatures.SelectFeatures line 217 file
c:\build_tux_area\mgdev\server\src\services\feature\ServerSelectFeatures
.cpp
	- MgServerSelectFeatures.JoinFeatures line 1008 file
.cpp
		All,
		Can an ODBC Feature Source be used in a Feature Join (as
the secondary feature)?
		Thanks,
		Keith
		This email and any attached files are confidential and
copyright protected. If you are not the addressee, any dissemination of
this communication is strictly prohibited. Unless otherwise expressly
agreed in writing, nothing stated in this communication shall be legally
binding.
	This message has been scanned for viruses by MailControl
<http://bluepages.wsatkins.co.uk/?4318150>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060908/d9964103/attachment.html
More information about the Mapguide-users mailing list
