[mapguide-users] POOL:DWF or AJAX
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Sep 14 13:57:13 EDT 2006
I've said this before, but I've got to say it again.....I wish that
either release dates were posted on the website, or else (ideally)
nightly / weekly builds could be made available.....
Andrew
Ivan Miličević wrote:
> Any release date?
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* 14. rujan 2006 18:10
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] POOL:DWF or AJAX
> Let's keep our fingers crossed!
> Andrew
> Jason Birch wrote:
> I haven't tested yet, but the MapGuide and FDO development projects
> have been working on this pretty actively, setting up pooled FDO
> connections and enhancing the ODBC provider.
> I'll be interested to see whether the changes made for the
> 1.0.2 release (which I'm guessing is the same as Enterprise
> SP1) resolves these issues as well as the Oracle performance problems.
> Jason
> *Sent:* Thursday, September 14, 2006 06:10
> *To:* users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
> I can certainly vouch for that....for me, ODBC is pretty much useless
> in AJAX because of the horrible speed. I had a few hundred
> points.....it's still slow in DWF if you do things like filters and/or
> themed layers., but it's at least useable.
> As for the OnSelect question, I have no idea. I'm not doing anything
> like that....though, I may at some point, I have no need just yet.
> Andrew
> I figured out that ODBC connection drasticly slow performance. In dwf that
> difference is not so big.  I've tested on 50 points. Measured by feeling ;-)
> I've restart OS every time after test so "feeling" is relevant.
> -----Original Message-----
> From: Traian Stanev [mailto:traian.stanev at autodesk.com]
> Sent: 14. rujan 2006 14:46
> To: users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
> Subject: RE: [mapguide-users] POOL:DWF or AJAX
> As far as the "everything is selectable" argument, you need to take into
> account the fact that if everything is selectable, it means ALL properties
> for all features need to be included with the DWF that gets sent to the
> client. They are all saved out in an XML file that is attached inside the
> DWF package. So depending on how many features you have and the ratio of
> viewing operations to selection operations the client is performing, the
> bandwidth wasted by that DWF could be larger than sending over a simple PNG
> and then processing a few mouse clicks on the server. So it's a double-edged
> sword.
> Traian
> From: Joel Carranza [mailto:jec at gatekeeper.com]
> Sent: Thursday, September 14, 2006 1:05 AM
> Subject: Re: [mapguide-users] POOL:DWF or AJAX
> AJAX viewer "bugless" ? That is a pretty bold claim :)
> While the "thinness" of the AJAX viewer certainly is appealing, I still get
> a little uncomfortable everytime I think about the additional burden it puts
> on the server in order to support selection and tooltips. We currently
> author maps where almost everything is selectable, almost every feature has
> a lengthy tooltip. In such an environment where users are doing alot of
> object selection and tooltips, I just don't think the AJAX viewer will be
> performant enough to satisfy our users moving from 6.5. I suspect alot of
> people don't have this problem, but i'm just throwing my 2 cents in.
> I'm a big fan of vector output, for a couple reasons:
> a) potentially more compact in terms of map request download
> b) ideal for "disconnected" applications (where network connectivity is not
> always available)
> c) absolutely necessary for printing
> d) easier to port existing MapGuide 6.5 applications
> I would love to see vector output in a different format. The DWF viewer is a
> major improvement over the MapGuide 6.5 viewer from our perspective because
> its so much easier for us to customize for our own purposes. However,
> deploying an ActiveX control is a big problem for alot of people. A java
> viewer leveraging an open vector format would be way cool. I don't see any
> reason why vector output should look worse than the raster output, although
> I agree it does. (Why doesn't the DWF viewer do anti-aliasing?)
> Something else that would be way cool that neither viewer has: Selected
> objects being drawn in something other than solid blue....
> Joel Carranza
> Gatekeeper Systems
>> Wich one you prefer?
>> For me, AJAX is better one.
>> Ajax:
>> -not needed plugin
>> -working with lot's of browsers
>> -visually looks better
>> -buugless
>> -more stable
>> DWF:
>> -faster
>> -better zooming, paning
>> Let's exchange expirience :-)
>> Ivan Miličević, voditelj razvoja
>> iNEO d.o.o.
>> 091 502 9672
> http://www.nabble.com/POOL%3ADWF-or-AJAX-tf2268101.html#a6299527
> Sent from the OSGeo MapGuide forum at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org <mailto:users-unsubscribe at mapguide.osgeo.org>
> For additional commands, e-mail: users-help at mapguide.osgeo.org <mailto:users-help at mapguide.osgeo.org>
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
