[mapguide-users] RE: Web Studio error
Martin Woods mwcourtenay at yahoo.com
Mon Apr 2 15:58:21 EDT 2007
Thank you very much, that did the trick.
I ran the uninstall and removed the .NET then re-ran the setup and installed
PHP and then had to run the setup again to re-install the .NET
Zak James wrote:
> Hi,
> You might want to look at this thread which covers some of the issues
> with using webstudio with a .NET install:
> http://lists.osgeo.org/pipermail/mapguide-users/2006-September/003100.html
> Unfortunately, we still haven't done anything to take care of this
> problem but I hope to have time to resolve it soon.
> zak
> On 3/30/07, citycourtenay <mwcourtenay at yahoo.com> wrote:
>> Yes, It's probably a PHP error, I chose the default install for .NET and
>> not
>> PHP but I quess PHP still gets installed in order to use the admin tools
>> The IIS Web server extentions are in place, and set for "allowed" .
>> I'm curious to hear how your install goes.
>> Yes Courtenay, B.C. (I think I might change that name :)
>> JasonBirch wrote:
>> > It might be a PHP error.  It might also be an IIS setting.  It's hard
>> to
>> > tell :)
>> > In your IIS admin console, do you have Web Service Extensions for
>> > FastCGI and PHP configured and set to Allowed?
>> > I'm about to do an install on a 2003 SP2 (not R2) server; I'll be able
>> > to help more once this is done.
>> > I have to ask:  citycourtenay:  Courtenay BC?
>> > Jason
>> > -----Original Message-----
>> > From: citycourtenay
>> > Subject: [mapguide-users] Web Studio error
>> > If I attempt :
>> > http://localhost/mapguide/webstudio
>> > I get the default webstudio ajax login dialog box with the user/pass
>> > already filled it along with the above URL but when I try login I get a
>> > IE dialog box stating " The URL you requested does not exist, please
>> try
>> > again"
>> > running on IIS 6, windows 2003 std server sp 2, IE 6 Installed the .NET
>> > web extentions and checked all the php settings with the manual,
>> > although none of the PHP pages will display either, I get a "Page not
>> > found". so it seems likely it is a php problem ?
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Web-Studio-error-tf3494506s16610.html#a9761700
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Zak James
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
View this message in context: http://www.nabble.com/Web-Studio-error-tf3494506s16610.html#a9797851
