[mapguide-users] patch for Mouse Wheel Zoom, set scale andimage on loading map in Ajax.
Brad Nesom kidsmake6 at msn.com
Tue Apr 3 21:59:58 EDT 2007
I vote for centering at the mouse cursor. both in and out.
I thought of a couple of further enhancements to the mouse wheel
handling, and I'd like to know what you think...
1) I'd like to re-draw the current map image dynamically as the user
scrolls the wheel, the same way that the map is re-drawn when the user
moves the zoom slider control.
2) Rather than re-centering the map at the location of the cursor, I'd
like to zoom in such a way that the real-world point at the cursor
remains the same. This is how the mouse wheel zoom currently works in
the DWF viewer.
I look forward to your comments.
Sincerely,
Chris Claydon.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Manuel
C G
Sent: April 3, 2007 9:51 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] patch for Mouse Wheel Zoom, set scale
Sorry. Here the rest of the code:
1) Mouse Wheel:
In Ajaxmappane.templ:
//Added by J M Cerrejon
function handle(delta,event) {
var isIE = document.all;
var x = isIE ? event.clientX - mapPosX : event.screenX - mapPosX;
var y = isIE ? event.clientY : event.screenY;
if (delta < 0)
	ZoomOut(x, y); // You can put here your function
else
	ZoomIn(x, y);
function wheel(event){
var delta = 0;
if (!event) event = window.event;
if (event.wheelDelta) {
delta = event.wheelDelta/120;
if (window.opera) delta = -delta;
} else if (event.detail) {
delta = -event.detail/3;
if (delta)
handle(delta,event);
if (window.addEventListener)
window.addEventListener('DOMMouseScroll', wheel, false);
window.onmousewheel = document.onmousewheel = wheel;
// End code
<script>
</head>
<body...
2) Input box to the scale (statusbar.templ):
var tempValue;
function CalcKeyCode(aChar) {
   var character = aChar.substring(0,1);
   var code = aChar.charCodeAt(0);
   return code;
function keyboardcontroller(val) {
   var strPass = val.value;
   var strLength = strPass.length;
   var lchar = val.value.charAt((strLength) - 1);
   var cCode = CalcKeyCode(lchar);
   if (cCode < 48 || cCode > 57 ) {
     var myNumber = val.value.substring(0, (strLength) - 1);
     val.value = myNumber;
   return false;
function setZoomToScale(val) {
	if (val.value == "") {
		val.value = tempValue;
		return;
	}else{
top.ViewerFrame.mapFrame.ZoomToScale(parseInt(val.value));
		val.value="1: " + val.value;
		document.getElementById(4).focus();
// End code
</script>
   </head>
   <body ...
...        <input class="StatusField" id="2" type="text" readonly >...
         <input class="StatusField" id="3" name="3" type="text"
onKeyUp="keyboardcontroller(this);" onKeyDown="if(event.keyCode==13)
document.getElementById(4).focus();" onfocus="this.style.backgroundColor
'lightyellow';tempValue = this.value; this.value='';"
onblur="this.style.backgroundColor = '#f0f0f0'; setZoomToScale(this);"
onclick="this.focus();">
<input class="StatusField" id="4" type="text" readonly >
View this message in context:
http://www.nabble.com/patch-for-Mouse-Wheel-Zoom%2C-set-scale-and-image-
on-loading-map-in-Ajax.-tf3491633s16610.html#a9816211
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
_________________________________________________________________
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/?icid=hmtag3
