[mapguide-users] build_oem.sh issues
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Apr 4 05:16:13 EDT 2007
Note: it's a good idea to include the full error stack so we can see
what the actual problem is.  The last line doesn't help much.
With ACE a common build problem involves the file Svc_Conf.l.cpp, and
the error message usually includes something involving "unterminated
if".  Is this the error you're getting?  You'll run into this problem if
you run aclocal / libtoolize / automake / autoconf / configure before
running build_oem.sh.  I suggest deleting your ACE directory and
re-extract it, and then try running build_oem.sh again.
Walt
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonathan
Bolich
Sent: Tuesday, April 03, 2007 8:50 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] build_oem.sh issues
I am trying to install mapguide but can't get past build_oem.sh
It fails with the ace 5.4 section. the final lines say:
make: *** [all] Error 2
ACE 5.4: Error build failed (0)....................
I tried to increase my swap space but that didn't change anything.
Any thoughts or things I could try I would be grateful
thanks
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070404/047687ee/attachment.html
