[mapguide-users] Unable to start mgserver.exe service on windows2003
Jason Birch Jason.Birch at nanaimo.ca
Sat Apr 21 12:14:13 EDT 2007
You can use:
netstat -abnp tcp
to see what's using the port that you require.  The -b option can be _extremely_ slow; you might want to try without it first.
The version I'm running (1.2.0-beta) appears to use ports 2810-12.
The ports used by MapGuide are specified in the serverconfig.ini file, typically located at:
C:\Program Files\MapGuideOpenSource\Server\Bin
Jason
From: mapguide-users-bounces at lists.osgeo.org on behalf of Nimrod Cnaan
Sent: Sat 2007-04-21 3:44 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Unable to start mgserver.exe service on windows2003
Unable to start the mgserver.exe service on 'windows 2003 SiteServer', the
service starts and then stops, lunching an unknown Error massage. When I try
to run the mgserver from command line I get the massage:
"Server starting . . . "
"Proj4 coordinate system library"
"Port 2801 is not availibale pleas try using different port  . . "
I'm using MGOS 1.1.0 inviroment
My Q are
1.      what protocol dose it need - TCP or UDP
2.      dose anyone know what this port are used for & would I need to open any
other ports.
3.      where can I find documentation  on those  subjects
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070421/a69dc77b/attachment.bin
