[mapguide-users] Markup SDF file format issue
Charles B cblais at dgeq.qc.ca
Fri Apr 27 09:32:51 EDT 2007
I am also interested to use shp instead of sdf with the markup tools.
Is there someone who modified the code and is willing to share it ?
Thanks
Charles
BradM wrote:
> The new markup tools work very well but the file format is SDF. In order
> to share the markup data with others, we must convert SDF/ access files to
> Shapefiles.  This is problematic unless you have a license for FME.   Is
> there a way to create shapefiles with the markup tools instead of SDF? or
> is there another way to convert sdf to shp without FME?
> thanks
View this message in context: http://www.nabble.com/Markup-SDF-file-format-issue-tf2920423s16610.html#a10219040
