[mapguide-users] Feature Joins Failing in MapGuide Open Source1.2.0
Dave Wilson dave.wilson at autodesk.com
Mon Apr 30 10:12:22 EDT 2007
What network ID do the other applications accessing the DSN connections
use? MapGuide by default runs the service as SYSTEM which may not have
network access to the files on the other server. If you change your
service to log on with an account that has network and specifically
share permissions to where the database files are on the other server
that may help, assuming of course you haven't done this already.
Regards,
Dave
-----Original Message-----
Sent: Friday, April 27, 2007 3:11 PM
To: Dave Wilson; MapGuide Users Mail List
Subject: Re: [mapguide-users] Feature Joins Failing in MapGuide Open
Source1.2.0
On Fri, 27 Apr 2007 13:29:37 -0700, Dave Wilson
<dave.wilson at autodesk.com>
wrote:
> I would expect an error if it wasn't, but your MySQL must be 5.022 or
> later because of an FDO requirement.
It is MySQL 5.0.24.
> The SQLServer should work. Could you try a connection string to
> SQLServer instead?
Using a connection string rather than a DSN makes no difference, for
either the SQL_Server or the MySQL connection.
James Card
California CAD Solutions, Inc.
209 578-5580
