[mapguide-users] 64 Bit
Berdel, Brian brian.berdel at mcmtrans.com
Mon Apr 30 16:51:46 EDT 2007
Isn't tracking it like a request? So we are more or less putting a
request for compatibility.  It really is also problem with the software,
in that it is not compatible with windows 64.  (I created a ticket)
Thanks,
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Monday, April 30, 2007 4:48 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] 64 Bit
Hi Bruce,
Is there really anything to be tracked from a MapGuide standpoint since
the
problem lies in the configuration of Windows and IIS?
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Monday, April 30, 2007 1:43 PM
To: MapGuide Users Mail List
Would either one of you like to create a trac ticket for this so that it
can
be tracked? :)
Thanks,
Bruce
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
Brian
Sent: April 30, 2007 2:40 PM
You were right Andy, I had to configure IIS for compatibility then
install
.NET 1.1 (I had 2.0 installed)
Thanks for your help, now I do not have to reinstall the OS.
Brian  Berdel
p: 215.283.9444
www.mcmtrans.com
Brian
Sent: Monday, April 30, 2007 4:29 PM
Thanks for the quick response Andy. I will look into it a little
further.
It would be nice if MapGuide could run on 64 bit without WOW64.  IIS
does
not support running both 32 and 64 bit apps and since this is an app
server
I might as well just reinstall the 32 bit OS.
Thanks again,
Brian  Berdel
p: 215.283.9444
www.mcmtrans.com
Morsell
Sent: Monday, April 30, 2007 3:27 PM
I installed MGOS (both 1.1.0 and 1.2.0 beta 1) on 64 bit Windows 2003
and
did not encounter that error.  I also integrated with IIS, and again, no
problems.  However, a network admin had setup and configured IIS, .NET,
PHP
etc. for 32 bit compatibility mode.  Sounds like you may have to do some
WOW64 troubleshooting to solve this one.
Or, your problem is related to WOW64 not being enabled at all and the 32
bit
PHP isapi is blowing up (since you are seeing this on the admin page).
See
this page: http://bugs.php.net/bug.php?id=33606&edit=1 near the bottom 4
or
so posts for how to enable 32 bit on 64 bit compatibility mode.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Brian
Sent: Monday, April 30, 2007 12:13 PM
Actually just noticed some posts related. I tried installing and I am
getting %1 is not a valid Win32 application when I try to go to the
admin
page.
Brian  Berdel
p: 215.283.9444
www.mcmtrans.com
Brian
Sent: Monday, April 30, 2007 3:08 PM
Subject: [mapguide-users] 64 Bit
Has anyone hear of a time frame for 64 bit support? I looked everywhere
and
cannot find anything related...
Thanks,
-Brian
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
