[mapguide-users] RE: Setting up own security with MapGuide
Ismael Cams mapguide2007 at gmail.com
Wed Aug 1 08:39:04 EDT 2007
These are non-geospatial databases. Basically I get the id of a feature (e.g.
parcelnumber) out of the map and need to get information out of these
databases based on the id. The kind of information is very different (e.g.
reports, parcel information). The used database vendors are ranging from SQL
Server, MS Acces to Oracle. The access is done with a direct connection (not
via FDO) towards the databases.
One thing that should be possible for example is to add new information to
the database based on a spatial filter in the map. But not everyone is
allowed to this, neither is everybody allowed to generate reports.
Each of these handlings are separate .aspx pages that need to be secured
based on the user that is logged in (windows users). Therefore I need to
work with Integrated Security.
Hope this gives a clear picture of what I try to achieve.
Martin Morrison wrote:
> What type of database?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ismael Cams
> Sent: Wednesday, August 01, 2007 3:54 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Setting up own security with MapGuide
> Hello,
> I have posted this message alreay a couple of times, but until now nobody
> could provide me with an answer.
> As I see this as a basic functionality on IIS I assume someone should have
> already ran into this problem too.
> I am using the .NET API to develop an application around MapGuide. This
> application is accessing external databases. I have set up my own
> application with Integrated Security in order to prevent unauthorized
> users
> from accessing this databases. Unfortunately this is causing problems with
> MapGuide. I have already tried to change the security of the MapGuide
> directories in different ways, but I run into the problem that either the
> viewer is not correctly working or I can not login to the MapGuide Studio
> anymore.
> Is it in first place possible to work with MapGuide and Integrated
> security
> and if yes how could this be achieved ?
> Is it maybe possible to disable the MapGuide security somewhere in the
> templates (note: I am providing the weblayout with user and password but
> without any result) ?
> This problem is keeping me busy already for months, therefore any help is
> highly appreciated.
> Kind regards,
> Ismaël
> http://www.nabble.com/Setting-up-own-security-with-MapGuide-tf4198581s16610.html#a11941302
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Setting-up-own-security-with-MapGuide-tf4198581s16610.html#a11944773
