[mapguide-users] Problem creating new Layer, Map or Feature Source
Zak James zak4ms at gmail.com
Wed Aug 1 10:15:16 EDT 2007
There are 2 conditions that can cause this less-than-helpful error
message to appear:
1. The server is responding to a request to generate a tree of the
resources in the repository but no data are loaded.
2. The attempt to create a new resource failed, potentially because
the logged in user does not have permission to create resources in the
repository.
Are you using IIS?
zak
On 8/1/07, Naumce Lazarevski <nume at mt.net.mk> wrote:
> Hi,
> I have reinstalled MG (1.1.0 and 1.2.0 RC1), uninstalled the anti virus and
> disabled the Firewall, but the situation is the same.
> When I try to create Datasource, layer or map, I receive message "ERROR: OK"
> Please help.
> Naumce
> Zak James wrote:
> > Naumce,
> > This can happen if you have antivirus or firewall software installed
> > that interferes with the ability of webstudio to communicate with the
> > server. Try disabling anything like that temporarily to see if it
> > clears up the problem.
> > zak
> > On 7/31/07, Naumce Lazarevski <nume at mt.net.mk> wrote:
> >> Hello MG community
> >> I have installed MG Open Source and sample data and application is Up and
> >> Running.
> >> On one test computer creation of new layer, data source or map is Ok, but
> >> on
> >> another computer (both with Windows XP) I can create folder in the
> >> library,
> >> but after creating map, layer or data source, I receive message "ERROR:
> >> OK".
> >> Naumce Lazarevski
> >> View this message in context:
> >> http://www.nabble.com/Problem-creating-new-Layer%2C-Map-or-Feature-Source-tf4193295s16610.html#a11925022
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > Zak James
> > Applications and Software Development
> > DM Solutions Group Inc.
> > http://www.dmsolutions.ca
> View this message in context: http://www.nabble.com/Problem-creating-new-Layer%2C-Map-or-Feature-Source-tf4193295s16610.html#a11945241
Zak James
