[mapguide-users] Solve problem MySQL Polygon Selection
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Aug 2 07:00:50 EDT 2007
I recall that there was a problem with selection/info in some version of
the OGR.
What version of the OGR provider do you use?
Does your server use 100% CPU before displaying?
Is the problem the same with tooltip's ?
Regards, Kenneth, GEOGRAF A/S
Dhirendra Kumar skrev:
> Hi Kenneth,
> Once again i am asking qustion to you about Postgres/PostGIS, Kenneth I
> import table in PostGIS database using shp2pgsql tool. I can create Layers
> from PostGIs Database. But when i select any polygon then polygon highlight
> after 4 second, So can i increase performence of polygon selection ? 300
> polygon on current layer. I also provide index but problem is still same.
> Any thing wrong in my process ? Please help me.
> Regards,
> Dhirendra Kumar
> Kenneth, GEOGRAF A/S wrote:
>> As someone else mentioned, the selection problem is a known bug in the
>> MySQL provider.
>> You have the following options:
>> 1. Wait until someone fixes the problem.
>> 2. Download source and fix it yourself (or perhaps pay someone to do it)
>> 3. Use another provider
>> If you MUST use a "real" database, I can only suggest Oracle (you have
>> tried the others).
>> Are there any reason that you cannot use SDF files?
>>> Hi All,
>>> Sorry for repeating this qustion. I tested MS SQL server, MySQL,
>>> Postgresql/postGIS and i got result MySQL performance is better in
>>> compare
>>> of all, but problem in polygon selection. I want to know that, no way to
>>> solve this polygon selection problem ? :(
>>> PROBLEM:- When i select some polygon then near polygon get highlighted in
>>> place of current selection.
>>> If anyone have idea or suggestion then please help me. Thankyou in
>>> Advance.
>>> Regards,
>>> Dhirendra Kumar
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070802/bb36c651/attachment.html
