[mapguide-users] Trouble making web layout work from session repository
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Aug 2 17:02:34 EDT 2007
There might be an UTF-8 header in the Xml.
Try downloading the modified file, and check it with a hex editor.
There should be no bytes before the "<" character.
I have filed a bug report on the problem.
Also, ensure that the document is encoded in UTF-8 (still without the
header).
Regards, Kenneth, GEOGRAF A/S
gom skrev:
> I am trying to load a modified map and web layout from the session
> repository. I have had success up to the final step.
> I get the mapdefintion from the repository
> I modify the XML to change the extents and save it to the session repository
> I get the weblayout from the repository
> I modify the XML to change the mapdefinition and save it to the session
> repository
> When I try to use the modified layout I get the following error.
> Argument is null.
> Argument is null. Exception occurred in method MgWebLayout.ParsePrintCommand
> at line 880 in file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\web\src\webapp\WebLayout.cpp
> If I just get the webLayout from the repositry and stuff it into the session
> repository I can then make that my current layout and it works great.  I
> call one function that changes the ResourceID under the Map node of the XML
> and it generates the above error.  Comparing the weblayout XML before and
> after I change the ResourceID seems to indicate that the files are identical
> except for the changed mapdefintion.  Any ideas what I might be doing wrong?
> Thanks
