[mapguide-users] Solve problem MySQL Polygon Selection
Dhirendra Kumar dhirendra.mgos at gmail.com
Fri Aug 3 00:53:13 EDT 2007
Hi Rahul-2,
I download OGR provider ( OGRProvider-3.2.2.win32.zip ) Release binaries for
windows from your given site. but i unable to establish connection. when i
unzip in server FDO directory and change in Provider.xml file and open
Studio 2007 and select OGR Provider then i saw nothing in Connection
properties ( Property and value option is blank). I repeating once again,
currently i using MGOS1.2.0 RC2. I also unzip this OGR provider in
FDO2FDO_v0_7_5 directory and when i try it then i get message unable to load
the FDO Provider: The specified module could not be found. Rahul where i am
wrong ? Kenneth If you are reading this message then i hope you can help me
Couz you already establish connection between PostGIS Database and OGR
Provider. Please Help Me. Thankyou in Advance.
Regards,
Dhirendra Kumar
Rahul-2 wrote:
> Hi,
>         Just check this link and download the OGR Provider Release
> Binaries for Windows.
>   http://fdo.osgeo.org/downloads.html
>   I think you wrote nice about Image Tool Tip but make it more clear in
> order to understand about dynamic images.
>   Cheers
>   Max !!
> Dhirendra Kumar <dhirendra.mgos at gmail.com> wrote:
> Hi Kenneth,
> Thankyou for your replay once again. If OGR provider have no problem in
> selection then i can use OGR Provider in place of PostGIS provider. I am
> using MGOS 1.2.0 RC2 and Autodesk MapGuide studio 2007. So, from where
> i'll
> get OGR Provider that work fine with MGOS 1.2.0 RC2. Thankyou in Advance.
> Regards,
> Dhirendra Kumar
> Kenneth, GEOGRAF A/S wrote:
>> I have no experience with the PostGIS provider.
>> I had no delays using OGR for PostGIS data.
>> Regards Kenneth, GEOGRAF A/S
>> Dhirendra Kumar skrev:
>>> Hi Kenneth,
>>> I make layer using PostGIS provider not OGR Provider. No problems with
>>> tooltips, it is working fine. only problem with polygon selection taking
>>> 4
>>> second to highlight. OGR Provider can solve this problem ? Yes Kenneth
>>> before displaying layer or map server use 100% CPU and before tool tips
>>> displaying server use 10-20% CPU. Any way to overcome this problem ?
>>> Regards,
>>> Dhirendra kumar
>>>> I recall that there was a problem with selection/info in some version
>>>> of
>>>> the OGR.
>>>> What version of the OGR provider do you use?
>>>> Does your server use 100% CPU before displaying?
>>>> Is the problem the same with tooltip's ?
>>>> Regards, Kenneth, GEOGRAF A/S
>>>>> Hi Kenneth,
>>>>> Once again i am asking qustion to you about Postgres/PostGIS, Kenneth
>>>>> I
>>>>> import table in PostGIS database using shp2pgsql tool. I can create
>>>>> Layers
>>>>> from PostGIs Database. But when i select any polygon then polygon
>>>>> highlight
>>>>> after 4 second, So can i increase performence of polygon selection ?
>>>>> 300
>>>>> polygon on current layer. I also provide index but problem is still
>>>>> same.
>>>>> Any thing wrong in my process ? Please help me.
>>>>> Regards,
>>>>> Dhirendra Kumar
>>>>>> As someone else mentioned, the selection problem is a known bug in
>>>>>> the
>>>>>> MySQL provider.
>>>>>> You have the following options:
>>>>>> 1. Wait until someone fixes the problem.
>>>>>> 2. Download source and fix it yourself (or perhaps pay someone to do
>>>>>> it)
>>>>>> 3. Use another provider
>>>>>> If you MUST use a "real" database, I can only suggest Oracle (you
>>>>>> have
>>>>>> tried the others).
>>>>>> Are there any reason that you cannot use SDF files?
>>>>>>> Hi All,
>>>>>>> Sorry for repeating this qustion. I tested MS SQL server, MySQL,
>>>>>>> Postgresql/postGIS and i got result MySQL performance is better in
>>>>>>> compare
>>>>>>> of all, but problem in polygon selection. I want to know that, no
>>>>>>> way
>>>>>>> to
>>>>>>> solve this polygon selection problem ? :(
>>>>>>> PROBLEM:- When i select some polygon then near polygon get
>>>>>>> highlighted
>>>>>>> in
>>>>>>> place of current selection.
>>>>>>> If anyone have idea or suggestion then please help me. Thankyou in
>>>>>>> Advance.
>>>>>>> Regards,
>>>>>>> Dhirendra Kumar
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Solve-problem-MySQL-Polygon-Selection-tf4170008s16610.html#a11963979
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Got a little couch potato?
> Check out fun summer activities for kids.
View this message in context: http://www.nabble.com/Solve-problem-MySQL-Polygon-Selection-tf4170008s16610.html#a11977437
