[mapguide-users] MGOS 1.2.0 On Linux: Error 559 MgFdoException Whe Selecting ODBC DSN
Zak James zak4ms at gmail.com
Fri Aug 3 15:33:38 EDT 2007
James,
In the providers.xml file within the fdo directory, there should be an
entry for ODBC. You need to make sure any shared libraries it
references are present. I don't have odbc setup on linux, but this is
usually a good troubleshooting step when a provider fails to execute.
zak
On 8/3/07, James Card <James.Card at calcad.com> wrote:
> On Fri, 03 Aug 2007 11:50:19 -0700, James Card <James.Card at calcad.com>
> wrote:
> > MapGuide Studio returns the following error when trying to select a DSN
> > for an ODBC data connection:
> >    Operation failed
> >    The remote server returned an error: (559) MgFdoException.
> Further detail from the MapGuide Server error log:
> <2007-08-03T11:26:22>                   Administrator
>   Error: An exception occurred in FDO component.
>          CLNT_8_UNABLE_TO_LOAD_LIBRARY
>   StackTrace:
>    - MgFeatureServiceHandler.ProcessOperation line 83 file
> FeatureServiceHandler.cpp
>    - MgOpGetConnectionPropertyValues.Execute line 116 file
> OpGetConnectionPropertyValues.cpp
>    - MgServerGetConnectionPropertyValues.GetConnectionPropertyValues line
> 128 file ServerGetConnectionPropertyValues.cpp
>    - MgFdoConnectionManager.Open line 368 file FdoConnectionManager.cpp An
> Any suggestions?
> James Card
> 209 578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
