[mapguide-users] ODBC Points Performance
Robert Bray rbray at robertbray.net
Mon Aug 6 11:45:49 EDT 2007
Jon,
Out of curiosity are the X and Y columns in SQL Server indexed? If not
try creating indexs on those columns and see if that helps at all.
Regards,
Bob
Jon Rizzo wrote:
> Thanks for the suggestion(s).  That is currently how we are serving up
> polygons - they are drawn in an SDF file but joined with data on a SQL
> Server so they can be labeled/themed.  The selection of the polygons suffers
> from the same problem as our point selection, so it stands to reason that
> your suggestion probably will not help.  Our data is updated frequently, so
> it's not realistic to copy all of the the data over to SDF files.  Again,
> that's really the whole point of having an enterprise database to begin
> with.  I think we may have to (*sigh*) continue using ArcIMS.  This is very
> disappointing to me, but it just appears to be better at what I'm trying to
> do.
> Also, I'm not even talking about 5,000 features here.  A typical map for us
> has 100 or so polygons and 10-20 points.  Our lag is more like 4 seconds
> instead of 10, but that's still enough to make our users crazy.
> Ismael Cams wrote:
>> I don't know if it is an option for you but it might be sufficient to put
>> only the x-y coordinates in an SDF together with a key that can be used to
>> do further database queries. These SDF's can be generated out of the SQL
>> server database you are using with some code.
>> To get properties and other information out of the database you could go
>> with an own faster database connection.
>> For the synchronization you could run the job for exporting the geometry
>> to SDF every day or so.
>> It needs some work, but for a layer with ~ 5000 points I had sometimes to
>> wait up to 10s before something got selected ...
