[mapguide-users] FDO provider for shp?
Mansoureh Sadrykia m_sadrykia at yahoo.com
Tue Aug 7 04:15:03 EDT 2007
Thank you very much Kenneth, GEOGRAF A/S for patiently answering my question,
  I tried what you said. The providers.xml could not be displayed using IE! the error was this: "Cannot view XML input using XSL style sheet." My fdo.dll version is 3.2.0 and although the providers.xml include the lines for 'fdo provider for shp' and 'fdo provider for sdf' these two are not shown in 'data connection' window in mg studio! Do I have to download any extra dll's in order to be able to connect to shp files? or not.
  2) Please explain me more about getting access to files from a network share, I really need to get access to shp files from different IP addresses and then bring them to studio in order to make web layouts.
  Lots of Thanks for your help,
"Kenneth, GEOGRAF A/S" <ks at geograf.dk> wrote:
  1) Yes, it should be there. Try opening the "providers.xml" with Internet Explorer to ensure that it is valid. The server must be restarted for any changes to take effect.
2) It is supposed to work that way.
3) The provider will have access to any and all files that the MapGuide Server service process has access to. This is usually the local system account. It will not have access to any network drives you have set up, and will use the local account for remote authentication. In other words, unless the files are in a share with anonymous access, it will probably not get access. Perfomance wise, I would also recomend against using files from a network share.
Regards, Kenneth, GEOGRAF A/S
Mansoureh Sadrykia skrev:     Hi List!
  I want to connect to shp files in a remote computer, and I've decided to use ' fdo provider for shp' in mapguide studio; Although I have the 'SHPprovider.dll' and the necessary code in 'provides.xml' in..\Bin\FDO directory I can't see osgeo FDO provider for shp when using New>Data Connection! ...1) should the provider for shp be there? 2) If not how can I  connect to shp files? 3) Can I connect to shp files in a remote computer in this way or there is another way?
  Please help me,
  Thanks in advance;
  Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase.
  _______________________________________________  mapguide-users mailing list  mapguide-users at lists.osgeo.org  http://lists.osgeo.org/mailman/listinfo/mapguide-users
Boardwalk for $500? In 2007? Ha!
Play Monopoly Here and Now (it's updated for today's economy) at Yahoo! Games.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070807/7ea22ca3/attachment.html
