[mapguide-users] MapAgent.exe persists after browser close
m.karam m21384k at yahoo.com
Tue Aug 7 04:19:53 EDT 2007
Hi
I have the same problem
I go to the Registery in (HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI)
What will i do with these registery keys?
thanks for help
Karam
None None-9 wrote:
> I am sorry, I have no clue about Apache on Windows and how it handles the
> FastCGI dll. I know on Linux this is not an issue. I do know however there
> is some registry information that pertains to max servers and other
> settings
> when used against IIS.
> The Rock
> On 7/17/07, Scott, Brian <ScottB at talgov.com> wrote:
>>  Hi The Rock -
>> Great name.  We are running Apache, not IIS.  Below is the fastcgi
>> configuration section from the httpd.conf file.
>> FastCgiConfig -idle-timeout 120 -startDelay 1 -minProcesses 4
>> -maxClassProcesses 40 -multiThreshold 100 -singleThreshold 100
>> -killInterval
>> 600
>> FastCgiServer "C:/Program
>> Files/MapGuideOpenSource/WebServerExtensions/php/php-cgi.exe" -processes
>> 4
>> -idle-timeout 120 -initial-env PHP_FCGI_MAX_REQUESTS=500 -initial-env
>> PHP_FCGI_CHILDREN=1
>> #Start PHP FastCGI config
>> ScriptAlias /php/ "C:/Program
>> Files/MapGuideOpenSource/WebServerExtensions/php/"
>> <Directory "C:/Program Files/MapGuideOpenSource/WebServerExtensions/php">
>>     Options ExecCGI
>>     AddHandler fastcgi-script exe
>> </Directory>
>> Action application/x-httpd-php5 "/php/php-cgi.exe"
>> AddType application/x-httpd-php5 .php
>> #End PHP FastCGI Config
>> #Start PHP Config
>> #ScriptAlias /php/ "C:/Program
>> #Action application/x-httpd-php "/php/php-cgi.exe"
>> #AddType application/x-httpd-php .php
>> #End PHP Config
>> I'm not too hip on FastCGI configuration, is there a mechanism to run as
>> a
>> process instead of an instance per process by modifying this
>> configuration?
>> Thanks for your help.
>> brian
>> -----Original Message-----
>> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
>> mapguide-users-bounces at lists.osgeo.org]*On Behalf Of *Rock Beans
>> *Sent:* Tuesday, July 17, 2007 9:30 AM
>> *To:* MapGuide Users Mail List
>> *Subject:* Re: [mapguide-users] MapAgent.exe persists after browser close
>> Make sure your using the FastCGI for the PHP and FCGI extentions within
>> IIS. This allows the php-cgi.exe and mapagent.exe to be run as a process
>> vs. a new instance per process.
>> The Rock
>> On 7/17/07, nicholda <nicholda at talgov.com> wrote:
>> > Thanks for your response Kenneth,
>> > Our issue seems to be that the functionality we are trying to provide
>> > winds
>> > up creating additional MapAgent.exe processes as a result of a
>> > successful
>> > run.  Essentially we are opening the map, creating serveral new layers
>> > with
>> > 1 to many points on each one, pushing the layers into the map, then
>> > storing
>> > the map back in the repository with the users sesssion.
>> > The report looks great.  However, when the map refreshes, it creates a
>> > new
>> > MapAgent.exe process.  So, if we create 40 reports, we reach max class
>> > processes reached and then have to manually go in and start killing
>> > processes / restarting MapGuide.
>> > The code we are using was taken / modified from the development guide;
>> I
>> > can
>> > tell you that we are not doing anything explicity to close any of the
>> > resource or feature services created; is there a chance that a simple
>> > featureService.close() or something related could keep this from
>> > happening?
>> > Or does the creation of new layers on the fly necessitate the creation
>> > of a
>> > new MapAgent.exe process and our only option includes kicking the
>> > timeout
>> > down from 120 seconds.
>> > Any and all insight is appreciated.
>> > Thanks,
>> > David
>> > Kenneth, GEOGRAF A/S wrote:
>> > > I belive that MapAgent.exe is supposed to keep running.
>> > > IIS/Apache will load/unload fastCGI, to avoid continously reloading
>> > > MapAgent.exe .
>> > > If you are using WinXP IIS, you are likely refering to the IIS
>> > > connection limit on WinXP.
>> > > You can increase the number of allowed connections to 40.
>> > > Instructions can be found here:
>> > > http://weblogs.asp.net/cazzu/archive/2003/10/10/31476.aspx
>> > > Regards, Kenneth, GEOGRAF A/S
>> > > nicholda skrev:
>> > >> Hi All,
>> > >>   I am having trouble with MapAgent.exe, after closing the web
>> > browser
>> > >> MapAgent.exe is still running in the background.  Eventually I hit
>> > the
>> > >> max
>> > >> number of connections and can't make another connection until I
>> > manually
>> > >> end
>> > >> the MapAgent processes running in the background.  I am running MGOS
>> > 1.2.
>> > >> Could someone point me in the right direction for resolving this
>> > issue.
>> > >> Thanks,
>> > >> David
>> > > _______________________________________________
>> > > mapguide-users mailing list
>> > > mapguide-users at lists.osgeo.org
>> > > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > View this message in context:
>> http://www.nabble.com/MapAgent.exe-persists-after-browser-close-tf4090604s16610.html#a11648611
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> This footnote confirms that this email message has been scanned by
>> PineApp Mail-SeCure for the presence of malicious code, vandals &
>> computer
>> viruses.
>> computer
>> viruses.
View this message in context: http://www.nabble.com/MapAgent.exe-persists-after-browser-close-tf4090604s16610.html#a12030277
