[mapguide-users] Mapguide server crashes on connection with ArcSDE 9.1
Ismael Cams mapguide2007 at gmail.com
Thu Aug 9 03:19:40 EDT 2007
Hello,
for a long time we had running a connection towards ArcSDE 9.1 without
problems. But now for some reason we can not seem to get it managed anymore.
When performing a Test Connection the mgserver.exe simply crashes. In the
event viewer I get following error message:
Faulting application mgserver.exe, version 1.1.0.301, faulting module
ArcSDEProvider.dll, version 3.2.0.26, fault address 0x00023a50.
In the error log the following error appears:
Resource was not found:
Session:cf94962e-ffff-ffff-8000-000e353f7d14_nl//FeatureSourceEditorsScratch/SessionVersion1.FeatureSource
We are able to choose the data store but as soon as we try to select the
version or perform a test connection the problem occurs. In the ArcSDE
logging we see there have been started SDE server processes but they are
stopped immediately with status 8 (lost client connection).
Both the MapGuide server and ArcSDE are running on the same server.
Does anyone have ideas what might cause the problem or how to locate the
problem ?
Thanks in advance.
Kind regards,
Ismaël
View this message in context: http://www.nabble.com/Mapguide-server-crashes-on-connection-with-ArcSDE-9.1-tf4241008s16610.html#a12067597
