[mapguide-users] How Can I load SDF
Jackie Ng jackie.ng at aecsystems.com.au
Thu Aug 9 05:47:55 EDT 2007
You should check the providers.xml you copied has valid paths for each
provider listed inside that file.
- Jackie
akramany wrote:
> Thank you Mr.Kenneth , I had added all DLLs in VB.NET reference from
> MapGuide installation's FDO folder but the same error still there , I
> think this maybe happened because I'm using trial version of Mapguide or
> what ?!
> Kenneth, GEOGRAF A/S wrote:
>> There are a number of Dll's that are needed for FDO to work.
>> You should ALL the files from a working MapGuide installation's FDO
>> folder,
>> into the folder you reference the .Net wrapper from.
>> The error 0x8007007E means "File not found",
>> indicating that you are missing some files.
>> As to the error with Studio; the load procedure is mostly unrelated
>> to the MapGuide server, so you should ask Autodesk about that problem.
>> There is no need/way to register the FDO dll's as they are not ActiveX
>> dll's.
>> Regards, Kenneth, GEOGRAF A/S
>> akramany skrev:
>>> When I import FDO as a reference in VB.NET and connect to SDF database
>>> format
>>> I have continual error  (Exception from HRESULT: 0x8007007E)  .
>>> Also I have continual error (Exception from HRESULT: 0×800700c1) when I
>>> load
>>> SDF or SHP data with Autodesk MapGuide studio , this problem since one
>>> month
>>> I don’t reach to the solution , kindly I would like to get the right
>>> solution in this matter if any one know .
>>> How can I Register FDO DLL ?!!
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/How-Can-I-load-SDF-tf4151735s16610.html#a12069465
