[mapguide-users] Uncontrolled Error Logging / Non Responsiveness in Apache
passionlessDrone ScottB at talgov.com
Thu Aug 9 11:05:21 EDT 2007
Hi -
Just in case someone else hits this, it looks as if modification to the
fastCGI configuration parameters in httpd.conf, can 'solve' this problem.
Based on some other fastCGI problems people were experiencing, I added this
clause to my FastCGIConfig line:
 -startDelay 45
I'm not sure exactly what the problem was, but my processes were taking a
while to repaint the map, I'm thinking maybe they were taking too long,
Apache would try to modify the process and a death spiral ensued.  Anyways,
as soon as I made this entry and toggled Apache, I have been unable to
disable MapGuide by submitting requests.
OK!
-pD
passionlessDrone wrote:
> Hello friends -
> MapGuideServer 1.2 / Apache / PHP on windows XP.  Every now and again
> running some reports that we have built will cause apache to freak out and
> start sucking up resources and locking browsers.  Apache goes absolutely
> nuts logging with statements like this:
> [Tue Aug 07 09:15:31 2007] [warn] FastCGI: (dynamic) server "C:/Program
> Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe"
> has failed to remain running for 30 seconds given 3 attempts, its restart
> interval has been backed off to 600 seconds
> It wrote 50MB+ of lines like this in three minutes.  I'm seeing other
> things that indicate this might be solvable via php configuration changes,
> but I was wondering if other folks have seen this with MG, and if so, what
> was the solution?
> Any insight is appreciated.
> -pD
View this message in context: http://www.nabble.com/Uncontrolled-Error-Logging---Non-Responsiveness-in-Apache-tf4230159s16610.html#a12074022
