[mapguide-users] programmatically add layer to initial map
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Aug 14 04:47:01 EDT 2007
Sorry, I don't have any code for it,
but you might be able to bend some of the PHP
samples in the developers guide.
Beware that the streams behave rather odd in .Net.
Also, I have reported quite a few bugs regarding the parsing of saved Xml.
Generally these rules must be followed:
1. Xml must be UTF-8 encoded.
2. Xml document must not contain UTF-8 byte-order mark.
3. Studio requires whitespace in the documents.
Regards, Kenneth, GEOGRAF A/S
Carl skrev:
> That does make perfect sense! The runtime map is being overwritten as I am
> still passing the web layout to the viewer as the original web layout from
> the library and not the session repository.
> Thank you for detailing the required steps, I am currently trying to code
> this in .Net, however as I am relatively new to the MapGuide API this may
> take me a little while!
> I don't suppose you have any code examples that I could follow or modify?
> Thanks again for your feedback.
> Carl Grice
> Keynetix Ltd
> Tel. +44 (0) 1527 68888
> Fax. +44 (0) 1527 62880
> Web Site: http://www.keynetix.com
> IMPORTANT: Please address all support & sales correspondence
> keynetix at key-systems.com.
> Addressing support questions to individuals may delay the response.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
> GEOGRAF A/S
> Sent: 13 August 2007 15:16
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] programmatically add layer to initial map
> When the viewer loads, it creates a map from the weblayout/mapdefinition
> passed.
> Your runtime map gets overwritten when the viewer starts.
> Instead you can do this:
> Initialize web tier
> Create a session, and open connection
> Use GetResource to retrieve the Xml for the WebLayout AND MapDefinition
> Modify the MapDefinition Xml to your liking (add layers etc.)
> Save the MapDefinition to the session repository, using SetResource.
> Update the WebLayout's map resourceid to point towards your modified
> WebLayout.
> Save the WebLayout to the session repositiory, using SetResource
> Start the viewer, pointing at the newly created WebLayout.
> You may of course use the "Library://" repository, if you want the
> changes to persist.
> Scott, Brian skrev:
>> Hi Carl -
>> What db are you using?  I found, for example, that I could not filter at
> run time against Postgres/PostGIS.  I was able to create a whole new layer
> based on points available in PG, but I  had to extact the attributes, create
> points, then apply them to a new layer.  Very cumbersome, but for whatever
> reason, filtering just wouldn't work w/PostGIS.
>> Good luck!
>> brian
>> [mailto:mapguide-users-bounces at lists.osgeo.org]On Behalf Of Carl Grice
>> Sent: Monday, August 13, 2007 10:01 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] programmatically add layer to initial map
>> Hi,
>> I am trying to programmatically filter and add a layer to a map that
> exists
>> in the repository before the map is initially loaded in the clients
> viewer.
>> The steps i am performing are as follows;
>> 1)Initialize the web teir and open site
>> 2)Create a new session and open a site connection
>> 3)Use map.create() to create a map from an existing map definition in the
>> repository
>> 4)Create a session resource identifier and use map.Save() to save the
>> existing map into the session repository
>> 5)Use map.Open() to open the map resource just created in the session
>> repository
>> 6)Use map.Getlayers() and insert() to add a new layer into the map
>> 7)use map.save() to save the map with the added layer into the session
>> repository
>> When i debug my code i get no errors and the map displays in the viewer
> but
>> the added layer does not (even after performing a map refresh).
>> Please can you point me in the direction of a sample that performs a
> similar
>> task or provide a code example? (I have found similar problems disscussed
>> but cannot find a solution)
>> Thanks in advance.
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070814/f705365b/attachment.html
