[mapguide-users] Filters cause Mapguide to crash
Joe Maurin junkstuff070771 at yahoo.com
Tue Aug 14 16:50:35 EDT 2007
In case anyone else gets this problem - Managed to fix this issue by including SHP and SDF in the connection pool. This is the setting in the C:\Program Files\MapGuideOpenSource\Server\Bin\serverconfig.ini file. You need to comment out the following :-
  DataConnectionPoolExcludedProviders=
  #OSGeo.SDF,OSGeo.SHP
  Thanks,
  Joe
Joe Maurin <junkstuff070771 at yahoo.com> wrote:    Has anyone else seen any major issues with using Filters ?
  When I apply filters to layers in my package, it crashes the map server process. It seems to have memory leak ? The process gets larger as I pan around the map until it eventually crashes, dependant on the resources of the machine. I've tested it in three seperate Windows environments and the same thing occurs. When I remove the filters it works fine. I have worked around the issue by filtering the data before loading into Mapguide, but this is not ideal. I'm using 1.2 on Windows with IIS.
  If someone else has the same issue, i'll log a bug ticket,
  Thanks,
  Joe
  Pinpoint customers who are looking for what you sell. _______________________________________________
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Moody friends. Drama queens. Your life? Nope! - their life, your story.
 Play Sims Stories at Yahoo! Games.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070814/0025cd91/attachment.html
