[mapguide-users] SDE Error with Search command
Micallef, Michael (MTO) Michael.Micallef at ontario.ca
Wed Aug 15 13:14:22 EDT 2007
I am using the FDO for ArcSDE connection to get at sde layers.   They
are displaying fine and I can select and get info back from them
But
When using the built in search function to go against the data I
continually get a "Unterminated string" Error and the map fails.
IU take the custom search out and the map  works.
Very basic search filter
"ASSESSMENT" LIKE '$USER_VARIABLE'
I can't get it to search against sde layers - tried 2
Shapefile layers work fine
Any help would be greatly appreciated!
Mike
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070815/7d49c5db/attachment.html
