[mapguide-users] programmatically add layer to initial map
Carl carl.grice at key-systems.com
Thu Aug 16 09:07:01 EDT 2007
Thank you for the suggestion, unfortunately I have just tried and resetting
the XML header as discussed does not seem to have made any difference.
I am still getting the same error message in the viewer;
The map definition is invalid.
The map definition is invalid. Exception occurred in method MgMap.Create at
line 303 in file c:\build_tux_area\mgdev\common\service\maplayer\Map.cpp
However I have written the MapDefinition XML to file and validated against
the MapDefinition Schema and it validates. I have compared the XML produced
in my code with an XML document from saved from studio and they also have an
identical structure. So I have no idea why the Map Definition is invalid.
Carl Grice
Keynetix Ltd
Tel. +44 (0) 1527 68888
Fax. +44 (0) 1527 62880
Web Site:  <http://www.keynetix.com/> http://www.keynetix.com
IMPORTANT: Please address all support & sales correspondence
<mailto:keynetix at key-systems.com> keynetix at key-systems.com.
Addressing support questions to individuals may delay the response.
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: 16 August 2007 12:22
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] programmatically add layer to initial map
You should insert the "UTF-8" header into the mapDoc.
On top of my head it is something like:
XmlNode decl = mapDoc.CreateXmlDefinition("1.0", "UTF-8");
mapDoc.Insert(0, decl);
You might have to remove an existing xmldefinition.
After that, you can get the byte stream, and it will be UTF-8 encoded:
MemoryStream xmlStream = new MemoryStream();
mapDoc.Save(xmlStream);
If your stream starts with:
byte[] { 0xEF 0xBB 0xBF };
you must remove those three bytes.
You can then get the byte array by:
byte[] utf8EncodedXml = xmlStream.ToArray();
And finally:
MgByteSource byteSource = new MgByteSource(utf8EncodedXml ,
utf8EncodedXml.Length);
byteSource.SetMimeType(MgMimeType.Xml);
Regards, Kenneth, GEOGRAF A/S
Carl skrev:
Following the logic below to create a weblayout and mapdefinition by
modifying the xml and using SetResource to save the updated xml into the
session repository, I am having some problems.
Initialize web tier
Create a session, and open connection
Use GetResource to retrieve the Xml for the WebLayout AND MapDefinition
Modify the MapDefinition Xml to your liking (add layers etc.)
Save the MapDefinition to the session repository, using SetResource.
Update the WebLayout's map resourceid to point towards your modified
WebLayout.
Save the WebLayout to the session repositiory, using SetResource
Start the viewer, pointing at the newly created WebLayout.
I am getting an error message 'The map definition is invalid.' when the
viewer loads.
The following code works no problem and the viewer displays the weblayout
and map from the session repository.
//Code above for modifying xml for web layout changing map resource and
persisting to session
MgResourceIdentifier mapResourceID = new
MgResourceIdentifier("Library://Demo/Maps/Demo.MapDefinition");
MgByteReader byteRdr2 = resService.GetResourceContent(mapResourceID);
String sessMapName = mapResourceID.GetName();
MgResourceIdentifier SessMapResId = new MgResourceIdentifier("Session:" +
sessionId + "//" + sessMapName + ".MapDefinition");
resService.SetResource(SessMapResId, byteRdr2, null);
//Loads into viewer no problem
But as soon as I try to load the map definition xml using SetResource I get
the invalid XML error
String mapResStr = byteRdr2.ToString();
//Load the web layout into an xml document
XmlDocument mapDoc = new XmlDocument();
mapDoc.LoadXml(mapResStr);
XmlElement mapRoot = mapDoc.DocumentElement;
byte[] mapDefinition = xmlStream.ToArray();
Encoding utf8 = Encoding.UTF8;
String mapDefStr = new String(utf8.GetChars(mapDefinition));
mapDefinition = new byte[mapDefStr.Length - 1];
int byteCount = utf8.GetBytes(mapDefStr, 1, mapDefStr.Length - 1,
mapDefinition, 0);
MgByteSource byteSource = new MgByteSource(mapDefinition,
mapDefinition.Length);
//Load the modified map into the session repository
resService.SetResource(SessMapResId, byteSource.GetReader(), null);
//This causes an invalid map error when the viewer loads
Any pointers on why manipulating the map definition is causing problems
would be great. Using the same techniques I am having no problems
manipulating the webDefintion or layerDefinition
Thanks
Carl Grice
Keynetix Ltd
Web Site: http://www.keynetix.com
-----Original Message-----
GEOGRAF A/S
Sent: 13 August 2007 15:16
When the viewer loads, it creates a map from the weblayout/mapdefinition
passed.
Your runtime map gets overwritten when the viewer starts.
Instead you can do this:
Initialize web tier
WebLayout.
You may of course use the "Library://" repository, if you want the
changes to persist.
Scott, Brian skrev:
Hi Carl -
What db are you using?  I found, for example, that I could not filter at
run time against Postgres/PostGIS.  I was able to create a whole new layer
based on points available in PG, but I  had to extact the attributes, create
points, then apply them to a new layer.  Very cumbersome, but for whatever
reason, filtering just wouldn't work w/PostGIS.
Good luck!
brian
[mailto:mapguide-users-bounces at lists.osgeo.org]On Behalf Of Carl Grice
Sent: Monday, August 13, 2007 10:01 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] programmatically add layer to initial map
I am trying to programmatically filter and add a layer to a map that
exists
in the repository before the map is initially loaded in the clients
viewer.
The steps i am performing are as follows;
1)Initialize the web teir and open site
2)Create a new session and open a site connection
3)Use map.create() to create a map from an existing map definition in the
repository
4)Create a session resource identifier and use map.Save() to save the
existing map into the session repository
5)Use map.Open() to open the map resource just created in the session
repository
6)Use map.Getlayers() and insert() to add a new layer into the map
7)use map.save() to save the map with the added layer into the session
repository
When i debug my code i get no errors and the map displays in the viewer
but
the added layer does not (even after performing a map refresh).
Please can you point me in the direction of a sample that performs a
similar
task or provide a code example? (I have found similar problems disscussed
but cannot find a solution)
Thanks in advance.
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070816/9e783521/attachment.html
