[mapguide-users] MG Fusion: Ruler Widget improvement
Paul Spencer pagameba at gmail.com
Fri Aug 17 08:30:19 EDT 2007
Rémy,
thanks for your contribution!  We will evaluate this for integration
into the ruler widget as we work to integrate Fusion into MapGuide OS
over then next few weeks or so.  You mention extending it to measure
area, which is interesting because that is on our todo list also.  In
fact, the intention is to rename the widget to Measure and provide a
way to measure distance, area or both at the same time.  We would be
tackling this in early September probably.  If you get there first,
let us know so we can spend time improving something else :)
Cheers
Paul
On 17-Aug-07, at 8:12 AM, web wrote:
> Hi all,
> don't know where to post some improvement I've done. Don't know
> too, if I'm right to post that here :-| ... I've added some options
> to the Ruler widget as fellowing:
> Here is the xml tag:
>         <Command xsi:type="FusionCommandType">
>             <Name>Ruler</Name>
>             <Label></Label>
>             <Tooltip>Measure distance</Tooltip>
>             <Units>Meters</Units>
>             <Precision>10</Precision>
>             <RulerTooltipContainer>RulerContainerBox</
>             <RulerTooltipType>dynamic</RulerTooltipType>
>                 <!-- Only if Static -->
>                <RulerTipPositionTop>0</RulerTipPositionTop>
>                <RulerTipPositionLeft>100</RulerTipPositionLeft>
>             <ImageURL>images/icons/measure.png</ImageURL>
>             <TargetViewer>All</TargetViewer>
>             <Action>Ruler</Action>
>         </Command>
> <Precision> Allows to display fixed distances: Enter 10 for 0.1,
> 100 for 0.01, etc...
> <RulerTooltipContainer> The ID of a <div> you placed in the form
> for Distances display. When not given, a new div will be built on
> the fly.
> <RulerTooltipType> dynamic: the distance display box (div) will
> felow your Mouse, as already implemented.
> static: The distance display box (div) will be placed on a specific
> location, given by the 2 fellowing tags: <RulerTipPositionTop> and
> Put this code in your css file or in the <style></style> of your
> sheet. This enables to customise the appearance of the display box.
> #RulerContainerBox {
>     font: 12px tahoma
>     position: absolute;
>     width: 110px;
>     float: left;
>     border: solid #cc9966 2px;
>     background-color: #B9C6E3;
>     display : 'none';
>     visibility : hidden;
> What would be very nice, is to create an implementation of a tag,
> that allows to choose between distance measuring or area measuring.
> I'll try to do that in the next weeks...
> Rémy
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
