[mapguide-users] SQL Server2005 & MapGuide Studio2007
Rahul unicorn_admirer at yahoo.com
Mon Aug 20 04:34:10 EDT 2007
Hi All,
              Currently i am working with SQL Server 2005 and already created the datastore and geospatial table using the Map3D 2007 ,I can view the layers and can do online editing ,updting features etc using the Map3D 2007.
  After working fine in Map3D I tried to figure it out with Autodesk MapGuide Studio 2007 and created a connection using the MGE 2007 with FDO Provider for SQL Server,I succesfully able to create the connection and use to get Data Resource and Feature Class with properties list from the SQL server but when i try to perfom theming and want to add rule using the condition and value(Get) ,it use to give error an Exception Occured in FDO Component.Table Does not exits for class'abc:Roads', although the table is available in the database and i can easily update and edit using the Map3D 2007.
  I also unable to view the layers in the Map or Layout Preview of the MapGuide Studio,I am bemused and any kind of reference/support will be of great help.
  Cheers
  Max !!
Sick sense of humor? Visit Yahoo! TV's Comedy with an Edge to see what's on, when.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070820/9d91c800/attachment.html
