[mapguide-users] Touches
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Aug 20 05:41:18 EDT 2007
If you look at the GetCapabilities of the SDF provider, you will see
that it supports the following spatial operators:
  Contains
  Disjoint
  Intersects
  Within
  Inside
  EnvelopeIntersects
So, there is no support for "Touches" with the SDF provider. Can you use
the "Intersects" instead?
Regads, Kenneth, GEOGRAF A/S
Mbonnet skrev:
> Hi,
> i want to use the spatial query Touches but, i have this Error : Operation
> spatiale FDO non prise en charge. so it says that i can't use this query, is
> it a known issue ?
> my code :
> queryOptions2.SetSpatialFilter(layerObj.GetFeatureGeometryName(),geometry,MgFeatureSpatialOperations.Touches);
> i use mapguide open source 1.2 rc2 with SDF files
> thanks
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070820/5389b7fa/attachment.html
