[mapguide-users] Connecting to remote files using mapagent [please help]
Mansoureh Sadrykia m_sadrykia at yahoo.com
Wed Aug 22 03:40:26 EDT 2007
Hi Jackie,
  1. You asked if the remote computer is on the same network as the mapguide server; Do You mean a "LAN", by "network" or
you mean the servers that we add in mapguide site administrator? You know, in my case the remote computers don't have mapguide installed.
  2. Actually I can't add new servers in mapguide site adminstrator,
and I guess that I make a mistake in defining IP addresses. Would you Please explain me how I can give IP addresses to different computers as different servers?
3.Would you please explain me more about how to create an unmanaged alias in the
MapGuide Site Administrator to the network share?
  Thanks in advance
  connecting to remote files using mapguide, please help
Jackie Ng <jackie.ng at aecsystems.com.au> wrote:
Is the remote computer on the same network as the mapguide server? Are the
shp files on a network share? If so you can create an unmanaged alias in the
MapGuide Site Administrator to that network share, and be able to refer to
that alias in your resource documents.
For example if your shp files are located at \\server\shp you can create an
alias "SERVER_SHP" that you can then refer to in your resource xml documents
as %MG_DATA_PATH_ALIAS[SERVER_SHP]%
So if you have a shp file called foo.shp in that network share you can
create a feature source document that refers to it by creating a document
that look like something below:
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
OSGeo.SHP
DefaultFileLocation
%MG_DATA_PATH_ALIAS[SERVER_SHP]%foo.shp
TemporaryFileLocation
Hope that helps.
- Jackie
Mansoureh Sadrykia wrote:
> Hi List!
> I intend to use mapagent to connect to shp files in a remote computer
> and decided to introduce the files' address, in the xml that I use in
> mapagent as the "content". Is it possible to introduce an IP address for
> the directory of shp files? Can map agent follow such an address and find
> the files?
> Thanks in advance for your help;
> Need a vacation? Get great deals to amazing places on Yahoo! Travel.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Connecting-to-remote-files-using-mapagent--tf4303364s16610.html#a12249882
Moody friends. Drama queens. Your life? Nope! - their life, your story.
 Play Sims Stories at Yahoo! Games.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070822/b354076c/attachment.html
