[mapguide-users] Connecting to remote files using mapagent [please help]
Jackie Ng jackie.ng at aecsystems.com.au
Wed Aug 22 19:31:19 EDT 2007
Are you using MGOS 1.2? This is a new feature of that version.
- Jackie
Mansoureh Sadrykia wrote:
> Thanks for your reply Jackie,
>   3. Unfortunately I couldn't find "configure external files" in mg site
> administrator. please tell me where it is,
>   second, Is there a way to share and access shp file in LAN network
> without using mg studio?
>   Thanks once again,
> Jackie Ng <jackie.ng at aecsystems.com.au> wrote:
> 1. By network, I mean a LAN that is correct.
> 2. I don't quite understand this question.
> 3. In the Site Administrator. Go to the "Add Alias" under "Configure
> external files". In there add your alias and external file path.
>> Hi Jackie,
>> 1. You asked if the remote computer is on the same network as the
>> mapguide server; Do You mean a "LAN", by "network" or
>> you mean the servers that we add in mapguide site administrator? You
>> know,
>> in my case the remote computers don't have mapguide installed.
>> 2. Actually I can't add new servers in mapguide site adminstrator,
>> and I guess that I make a mistake in defining IP addresses. Would you
>> Please explain me how I can give IP addresses to different computers as
>> different servers?
>> 3.Would you please explain me more about how to create an unmanaged alias
>> in the
>> MapGuide Site Administrator to the network share?
>> Thanks in advance
>> connecting to remote files using mapguide, please help
>> Jackie Ng wrote:
>> Is the remote computer on the same network as the mapguide server? Are
>> the
>> shp files on a network share? If so you can create an unmanaged alias in
>> the
>> MapGuide Site Administrator to that network share, and be able to refer
>> to
>> that alias in your resource documents.
>> For example if your shp files are located at \\server\shp you can create
>> an
>> alias "SERVER_SHP" that you can then refer to in your resource xml
>> documents
>> as %MG_DATA_PATH_ALIAS[SERVER_SHP]%
>> So if you have a shp file called foo.shp in that network share you can
>> create a feature source document that refers to it by creating a document
>> that look like something below:
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>> OSGeo.SHP
>> DefaultFileLocation
>> %MG_DATA_PATH_ALIAS[SERVER_SHP]%foo.shp
>> TemporaryFileLocation
>> Hope that helps.
>> - Jackie
>>> Hi List!
>>> I intend to use mapagent to connect to shp files in a remote computer
>>> and decided to introduce the files' address, in the xml that I use in
>>> mapagent as the "content". Is it possible to introduce an IP address for
>>> the directory of shp files? Can map agent follow such an address and
>>> find
>>> the files?
>>> Thanks in advance for your help;
>>> Need a vacation? Get great deals to amazing places on Yahoo! Travel.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Connecting-to-remote-files-using-mapagent--tf4303364s16610.html#a12249882
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> Moody friends. Drama queens. Your life? Nope! - their life, your story.
>> Play Sims Stories at Yahoo! Games.
> http://www.nabble.com/Connecting-to-remote-files-using-mapagent--tf4303364s16610.html#a12270055
> Got a little couch potato?
> Check out fun summer activities for kids.
View this message in context: http://www.nabble.com/Connecting-to-remote-files-using-mapagent--tf4303364s16610.html#a12284927
