[mapguide-users] Starting MapGuide Studio with another user
Ronnie Louie ronnie.louie at autodesk.com
Thu Aug 23 12:44:49 EDT 2007
The issue has been fixed in the current release of Autodesk MapGuide Studio (1.2.0.4103).  It is also mentioned here http://discussion.autodesk.com/thread.jspa?threadID=565387 in the Autodesk Discussion Groups.
Ronnie
-----Original Message-----
From: Ismael Cams [mailto:mapguide2007 at gmail.com]
Sent: Tuesday, August 21, 2007 7:40 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Starting MapGuide Studio with another user
Hello Kenneth,
thanks for pointing this out. As not everyone is allowed to log in as
administrator this is a problem, but as you said it is unrelated to MGOS.
Kind regards,
Ismaël
Kenneth, GEOGRAF A/S wrote:
> I have written Autodesk about that problem (it is unrelated to the
> MapGuide Open Source project),
> and they explain that running MapGuide Studio in a non-administrator
> account is not supported.
> Neither is Citrix if you are interrested.
> Regards, Kenneth, GEOGRAF A/S
> Ismael Cams skrev:
>> Hello,
>> I have installed MapGuide Studio with the Administrator account. When I
>> use
>> the same account to start the Studio and log in everything works fine,
>> but
>> when I log in with a more restricted user I can not connect to the
>> MapGuide
>> site anymore.
>> Can the MapGuide Studio only be started with the same user that was used
>> for
>> installing it ?
>> Kind regards,
>> Ismaël
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Starting-MapGuide-Studio-with-another-user-tf4304993s16610.html#a12254830
