[mapguide-users] Problem in loading SDF data in Mapguide Webstudio
Kenneth, GEOGRAF A/S ks at geograf.dk
Sat Dec 1 07:54:41 EST 2007
MapGuide Studio is a ful product with Autodesk support.
WebStudio is an opensource web based product.
In essence they accomplish the same task, however WebStudio does not
have any direct funding.
This means that it will not always be stable/updated, unless some
volunteer does some work on it.
Currently there is no editor for WebLayouts in WebStudio.
This limitiation is quite severe, as the AJAX and DWF viewers are based
on a WebLayout.
In other words, you will not be able to build a solution that works
right away, using only WebStudio.
Secondly, there is no legal way for an opensource product to support
proprietary formats (such as DWG and ArcSDE).
MapGuide Studio can overcome this limitation, since it is not open source.
Regards, Kenneth, GEOGRAF A/S
Parvatha skrev:
> Hi Kenneth,
>  Thanks for your reply. The problem is not with sdf and with upload data
> only. With studio preview its working well. But i want to understand the
> need of web studio and its limitations.
> Thanks and Regards
> Parvatha
> Kenneth, GEOGRAF A/S wrote:
>> You should use the "Load Procedures" from within MapGuide Studio.
>> The load procedures are missing from WebStudio, because the Load
>> procedures read proprietary data formats and converts them to SDF for
>> use in the server.
>> WebStudio is missing the "Load Procedures" and currently an editor for
>> WebStudio.
>> What you describe means that there is no spatial data inside the loaded
>> SDF files.
>> Please try again with different data. If you suspect that the problem is
>> with the load procedures,
>> you can ask Autodesk for support.
>> Parvatha skrev:
>>> Can anybody help me to solve this issue in webstudio?
>>> Parvatha wrote:
>>>> Hi
>>>>  I am new to MapGuide Opensource. I have downloaded version 1.2 of MGOS
>>>> and it has got webstudio in that. I am using .NET 2 and able to see the
>>>> sample data.
>>>>  My problem is when i try to load SDF data the sytem takes few seconds
>>>> then in data file resources window its showing the file name. But when i
>>>> create one layer and try to give this as data source its not showing any
>>>> feature class and geometry. I dont know what is the problem in loading
>>>> the
>>>> sdf data. Can anybody please help me to solve this issue.
>>>>  I have downloaded the trail version of MG studio preview also. With
>>>> that
>>>> I am able to do all these things. But basically I want to understand the
>>>> need of webstudio and the limitations. Is it necessary to do everything
>>>> in
>>>> MG studio only? then what is the purpose of web studio?
>>>> Thanks and waiting for the response
>>>> Parvatha
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071201/b9ce5e9e/attachment.html
