[mapguide-users] SUSPECT: RE: Printing
Jackie Ng jackie.ng at aecsystems.com.au
Tue Dec 4 02:25:27 EST 2007
As the one who initially pitched the idea of code samples, I was going to put
up some myself, but I've been busy as hell since I pitched the idea, so
that's why the code samples area looks pretty blank at the moment :)
- Jackie
uXuf wrote:
> So who'd take the initiative for actually putting up further useful
> samples?
> uXuf
> ctallman wrote:
>> Dennis,
>> Thanks for sharing your work with the group.
>> Chris
>> ________________________________
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonio,
>> Dennis (Aviation)
>> Sent: Wednesday, November 21, 2007 3:40 PM
>> To: MapGuide Users Mail List
>> Subject: RE: SUSPECT: RE: [mapguide-users] Printing
>> Chris, Martin, Maksim
>> After working through our various "virus scanner" and "router port
>> closed" issues. Jason has the zip and has already started putting
>> together the page for your access. It is not obvious to me how it will
>> be accessible but I am sure he knows the way and will let us know.
>> Again ... thank you Jason.
>> Happy Turkey Day!!!
>> dennis
>> -----Original Message-----
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
>> Sent: Wednesday, November 21, 2007 1:23 PM
>> Hi Dennis,
>> The main osgeo wiki (wiki.osgeo.org) is different technology than the
>> wiki in the MapGuide Trac instance, and does use OSGeo IDs.  We don't
>> have single-sign-on though, so if you want to log in to the MapGuide
>> wiki, you have to click on the "Login" link under the search box and log
>> in there, not through the main OSGeo web site.  And you have to log in
>> every time you visit the site; it doesn't remember your credentials.
>> I'd be happy to post the zip and a description if you want to email it
>> to me offline.  My tech group just started allowing zipfiles through
>> again, so maybe I'll get lucky, but maybe not.  If not, I'll reply with
>> FTP details you can use.
>> Jason
>> Dennis (Aviation)
>> Sent: Wednesday, November 21, 2007 09:38
>> Subject: SUSPECT: RE: [mapguide-users] Printing
>> Jason,
>> I have just read this:
>> The following services do not yet use the central OSGeo userid.
>> *         Wiki <http://wiki.osgeo.org/> : The main OSGeo wiki uses it's
>> own userid list for those wanting to edit, but it is easy to signup for
>> a wiki userid. Please make sure to add your email address to the
>> appropriate field because it is used to verify you are a real person.
>> Before that it is not possible to edit the Wiki.
>> *         Shell access to the telascience blades used for various
>> project services (ie. buildbot.osgeo.org, buildbot.osgeo.org).
>> *         Shell access to primary OSGeo server - available by special
>> arrangement with the System Administration Committee
>> This then explains why I never see .. "logged in as xxx"
>> ... and frankly all this is getting to be a bit much for me.
>> I do not wish to be forward and impose but why don't I email you the ZIP
>> and you then can post it? There is a README that explains.
>> This would also give you a chance to review the contents first.
>> dennis
>> E-mails are automatically scanned for viruses using McAfee.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Printing-tf4836766s16610.html#a14145914
