[mapguide-users] Mapguide 2.0 Beta1 Documentation
Zac Spitzer zac.spitzer at gmail.com
Tue Dec 4 21:19:19 EST 2007
Not directly fusion related, but is there going to be any
doco/examples on the use of CompositeTypeStyle in a layer def?
On Nov 30, 2007 2:15 AM, Paul Spencer <pagameba at gmail.com> wrote:
> Hi Bruno,
> sorry for the delay.  Documentation is being developed, there are a
> couple of technical writers working on stuff now.
> There should only be 2 css files (style.css seems to have been
> removed, I think it was extraneous) that have the following purposes:
> jxskin-border.css
> This file is copied directly from the Jx project and establishes a
> base set of CSS rules that govern all the Jx components.  To modify
> button sizes, you need to override settings in this file.  This can be
> done by copying and then editing this file and using the copy in place
> of this file, or by adding another file that just redefines the styles
> you want to override in your template.  Either approach is fine, but
> for the mapguide templates, we took the second approach.
> maroon_fusion.css
> This file has all the overrides for Jx to give the template its
> current colour scheme.  It also contains any styles specific to this
> template.
> I think your question about how to change the size of the icons is
> going to be a common one, so I am going to start a F.A.Q. and include
> that specific question.  I will also try to find the right answer
> (since CSS isn't my strong point) and post it back to the list :)
> The documentation for creating new widgets will likely come a little
> later.  At this point, you can do what we do, which is to copy an
> existing widget that does something similar (from a user's
> perspective) and modify it.  To do this, it is important to know that
> the file name and class name in the javascript file are case sensitive
> and have to be identical, and that is the name you use in the <Type>
> tag in the ApplicationDefinition.xml file.
> Cheers
> Paul
> On 26-Nov-07, at 2:56 AM, Bruno Scott wrote:
> > I'm trying to figure out how to create new templates and it's not easy
> > without documentation.
> > I would like to change the colors, i know there are some css but
> > playing
> > with them is time consuming.
> > For one template we have 3 css
> >  fusion\templates\mapguide\maroon\css\jxskin-border.css
> >  fusion\templates\mapguide\maroon\css\maroon_fusion.css
> >  fusion\templates\mapguide\slate\theme\default\style.css
> > If i want to replace 16x16 toolbar images by 32x32 images, where do
> > i go?
> > I would also being able to create new components.
> > Can we expect a documentation in the near futur?
> > View this message in context: http://www.nabble.com/Mapguide-2.0-Beta1-Documentation-tf4874465s16610.html#a13947573
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
