[mapguide-users] how to create an mgp file?
Paul Spencer pagameba at gmail.com
Sat Dec 8 12:07:47 EST 2007
Parvatha,
rename the extension of the file to .mgp.  The .mgp format is actually
a zip file containing XML files.  Your browser helpfully detected the
actual type of the file and renamed it for you ... thank you IE.
Paul
On 5-Dec-07, at 11:35 PM, Parvatha wrote:
> Hi
> can anybody tell me how to create an mgp file? when i download the
> sample
> (sheboygan) data for mapguide opensource 1.2 its a zip file. When i
> unzip
> that i could see all xml files. Using mapadmin if i load that mgp
> then in
> the "library" folder in local there is a "data" folder in that all
> sdf files
> are loaded. I dont understand from where it is getting loaded
> dynamically.
> If this is the way then how to create xml file for my own sdf data
> to make
> an mgp? and where to keep the sdf? bcoz in xml file only the sdf
> name has
> given and the path is not given. Can anybody please calrify my doubt?
> Regards
> Parvatha
> View this message in context: http://www.nabble.com/how-to-create-an-mgp-file--tf4953979s16610.html#a14186172
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
