[mapguide-users] Using X,Y from Oracle
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Dec 10 09:51:25 EST 2007
That seems to be exactly what I want.
Thanks!
Regards, Kenneth, GEOGRAF A/S
Bruno Scott skrev:
> You need to use the KingFdoClass table to be able to use x,y.
> With this metadata table you can also overide lots of defaults.
> Like geometry type, by the way
> You can find the description of this table at www.sl-king.com.
> Fdo2fdo help you create and manage this table
> Bruno
> Kenneth, GEOGRAF A/S wrote:
>> I have tried to produce points from an Oracle database with only x and y
>> data, no SDO geometry.
>> Using King.Oracle these tables do not appear, using the Autodesk
>> provider shows these, but does not allow for mapping with X/Y.
>> I then tried to load the Oracle as an ODBC connection.
>> After waiting approximately 10 minutes after pressing save, the
>> FeatureSource is saved.
>> After this, there are no tables listed in the FeatureSource.
>> Can I fix this somehow, or is it better to convert the columns to SDO?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071210/3feaa53b/attachment.html
