[mapguide-users] how to create an mgp file?
Zac Spitzer zac.spitzer at gmail.com
Tue Dec 11 07:18:44 EST 2007
now it's clearer what you are trying to do!
you can use an unmanaged feature source, which means you reference a sdf
file on
the server which lives outside the repository.. there for you bypass
webstudio...
the xml looks like, where C is a directory on your server
<?xml version="1.0" encoding="ISO-8859-1"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="
FeatureSource-1.0.0.xsd">
   <Provider>OSGeo.SDF</Provider>
   <Parameter>
      <Name>File</Name>
      <Value>c:\data\DEMO~GEOMETRY.sdf</Value>
   </Parameter>
   <Parameter>
      <Name>ReadOnly</Name>
      <Value>TRUE</Value>
   </Parameter>
</FeatureSource>
Otherwise you can use the API in .NET, PHP or Java to upload into the
repository
z
On Dec 11, 2007 11:09 PM, Parvatha <kpeswari at indiainfo.com> wrote:
> I am unable to load my SDF data using web studio; So i am trying someother
> way. If I can convert my data to mgp format then there is no need to load
> the sdf i think. I need to load only the mgp using mapadmin. This will
> also
> solve my problem. I have sdf but i dont know how to create xml files. So
> that if I have xml and sdf then i can make mgp. This is what my problem.
> Kenneth, GEOGRAF A/S wrote:
> > Its not clear to me, what you want to do.
> > You can create MGP packages from an entire folder.
> > You can modify the MGP file as a Zip file afterwards.
> > AFAIK, there is no documentation for the MGP format.
> > The format is quite simple, the MGP is a Zip file, which contains all
> > the data, SDF and Xml.
> > There is a manifest file in the MGP, which contains operations executed
> > agains the server.
> > These operations execute the actual data storage of either SDF or Xml
> > data.
> > The SDF files are usually stored as "ResourceData" on a FeatureSource
> > (Xml).
> > Regards, Kenneth, GEOGRAF A/S
> > Parvatha skrev:
> >> In site administrator we can create mgp files but for that we need to
> >> have
> >> xml files in a folder which has got the details of the sdf data. I want
> >> to
> >> know how to create those xml files and where to keep the sdf data and
> >> what
> >> is the format?
> >> zspitzer wrote:
> >>> you can create a mgp via the mapguide site administrator
> >>> On Dec 6, 2007 3:35 PM, Parvatha <kpeswari at indiainfo.com> wrote:
> >>>> Hi
> >>>>  can anybody tell me how to create an mgp file? when i download the
> >>>> sample
> >>>> (sheboygan) data for mapguide opensource 1.2 its a zip file. When i
> >>>> unzip
> >>>> that i could see all xml files. Using mapadmin if i load that mgp
> then
> >>>> in
> >>>> the "library" folder in local there is a "data" folder in that all
> sdf
> >>>> files
> >>>> are loaded. I dont understand from where it is getting loaded
> >>>> dynamically.
> >>>> If this is the way then how to create xml file for my own sdf data to
> >>>> make
> >>>> an mgp? and where to keep the sdf? bcoz in xml file only the sdf name
> >>>> has
> >>>> given and the path is not given. Can anybody please calrify my doubt?
> >>>> Regards
> >>>> Parvatha
> >>>> View this message in context:
> http://www.nabble.com/how-to-create-an-mgp-file--tf4953979s16610.html#a14186172
> >>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >>>> _______________________________________________
> >>>> mapguide-users mailing list
> >>>> mapguide-users at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >>> Zac Spitzer -
> >>> http://zacster.blogspot.com (My Blog)
> >>> +61 405 847 168
> http://www.nabble.com/how-to-create-an-mgp-file--tp14186172s16610p14272461.html
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071211/bd054a13/attachment.html
