[mapguide-users] Shortest path between two points
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Dec 14 16:14:07 EST 2007
You can do a select on the featuresource to get all data for the resource.
You can choose only to select the geometry column.
When you itterate over the records, you can extract the geometry from
the record.
This involves converting AGF data to GML (or whatever you prefer).
The basis for query to a featuresource, and extraction of geometry is
documented with an example in the developer guide (PDF version at least).
If you get stuck on the examples, please ask again.
Regards, Kenneth, GEOGRAF A/S
ruivilanova skrev:
> I all,
> I understood the way to find the shortest path between two points and I also
> have the  http://en.giswiki.net/wiki/Dijkstra's_algorithm#PHP php code of
> dijkstra algorithm , but I don't know how to fill that array of nodes.
> Any ideias of how to get the nodes from a linestring feature source?
> Thanks in advance,
> Rui
