[mapguide-users] Can anyone tell me why I can't do a refresh
Gord McKenzie gord.mckenzie at canam.com
Fri Dec 14 16:45:55 EST 2007
Thanks Kenneth
I am embarrassed.  I know javascript is case sensitive and I played with
caps for the frame names etc.  I even have it right in the html button code.
Thanks for taking the time to answer the dumb question of the day. :)  I
will try the GetMapFrame as well as that will definitely save some headache.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Friday, December 14, 2007 2:18 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Can anyone tell me why I can't do a refresh
The frame hierachy problem aside, the function is called "Refesh()" not
"refresh()".
Also, most frames have a function called "GetMapFrame()", that will ease
the problem of finding the right frame.
Regards, Kenneth, GEOGRAF A/S
gom skrev:
> I have the following code in vb.net.  I get a javascript error when I try
to
> do the refresh.  If I place an html button in the page and execute
> parent.parent.mapFrame.refresh();  It refreshes the map with my group
turned
> off.  For some reason, when I execute the sub as shown below,
> parent.parent.mapFrame is not valid but parent.mapFrame is.  Same page as
> the html button but obviously executed differently.  The debugger shows
that
> parent is viewFrame in this context and parent.mapFrame is valid.
However,
> the refresh throws an error saying object or method does not exist.  I
feel
> like I'm missing something obvious but cannot discover what it is.  Anyone
> have any help.
> Thanks in advance.
> Protected Sub RadioButton1_CheckedChanged(ByVal sender As Object, ByVal e
As
> System.EventArgs)
>         InitializeWebTier()
>         Dim mySiteConnection As New MgSiteConnection
>         Dim myUserInfo As New
> MgUserInformation(Session.Item("sessionID").ToString)
>         mySiteConnection.Open(myUserInfo)
>         Dim myFeatureService As MgFeatureService =
> mySiteConnection.CreateService(MgServiceType.FeatureService)
>         Dim myResourceService As MgResourceService =
> mySiteConnection.CreateService(MgServiceType.ResourceService)
>         Dim myMap As New MgMap
>         myMap.Open(myResourceService, m_CurrentMap())
>         Dim myLayerGroup As MgLayerGroup = Nothing
>         Dim myLayerGroups As MgLayerGroupCollection = myMap.GetLayerGroups
>         Dim i As Integer = 0
>         For Each myLayerGroup In myLayerGroups
>             If myLayerGroup.Name = "Group1" Then
>                 myLayerGroup.SetVisible(False)
>             End If
>         Next
>         myMap.Save()
>         Dim myKey As String = "mapRefresh"
>         If Not Page.ClientScript.IsStartupScriptRegistered(Me.GetType,
> myKey) Then
>             Dim myScript As String = "parent.mapFrame.refresh();"
>             Page.ClientScript.RegisterStartupScript(Me.GetType, myKey,
> myScript, True)
>         End If
> End Sub
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
