[mapguide-users] Trusted Sites
KRUEGER, JAMESBRIAN B (ATTSI) jk3854 at att.com
Wed Dec 19 14:18:21 EST 2007
Chris
I am not able to get the tooltip, or select anything on the test site.
James B Krueger
Phone 847-248-2144
Cell 630-674-0834
E-Mail
JK3854 at ATT.COM
SAP, MapGuide, and AutoCAD now,
We Are Connected
"Restricted - Proprietary "
RESTRICTED - PROPRIETARY INFORMATION
The Information contained herein is for use only by authorized employees
of AT&T Services, Inc., and authorized Affiliates of AT&T Services,
Inc., and is not for general distribution within or outside the
respective companies.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Tallman
Sent: Wednesday, December 19, 2007 1:08 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Trusted Sites
Ok it appears to be a bug in Mapguide.  If you turn the properties pane
off in your map it causes the problem.  I turned it back on and the map
performs perfect.  If someone else can verify this it should be
submitted as a report so it gets fixed.  Unless it already is one.
Chris
Tallman
Sent: Wednesday, December 19, 2007 11:36 AM
Alright well this is going down a completely different track now.  There
is an oddity and I'm not sure what part is causing it.  When the site is
not trusted everything works as it should.  Hover over a point feature
and you see a tool tip along with being able to select the feature.
With the cursor directly over the feature.  Once the site is trusted
something changes, and here is where it gets odd and goes down a
different track then before.  This is where I was wrong, You can still
select and hover and get the tooltip the only problem is you have to
hold the cursor north of the feature you want to select.  I tried to get
a screen shot but the cursor doesn't get captured.
Probably has nothing to do with trusted or not it's the MSXML 5.0 being
enabled.  I think.  I've tried this theory on two different machines
looking at the same map and was able to reproduce the results.
I created a temporary test site that you can look at and see if you get
the same results at:
https://mgos.innomap.com/mapguide/taylortest
Take a look and let me know if you get the same results.  I'll leave the
site up today or till we figure out the issue.
Thanks,
Chris
Tallman
Sent: Wednesday, December 19, 2007 9:04 AM
Ok well nevermind my last email I figured out what needs to be replaced
to update the sarissa.  All that did was make it so now I can't select
point features if the site is trusted or not.
However...
I've had a new development that might lead to a solution.  Having that
MSXML 5.0 control enabled is a trigger however I have some other maps
that are not effected by this.  So two maps setup the same using
basically the same data providers, one having the issue the other not.
The only thing I can think of that is different between the two is one
is under a secured site and the other is not.  Does anyone have any
thoughts on this causing an issue?
Chris
Tallman
Sent: Wednesday, December 19, 2007 8:41 AM
Well I didn't mean to send that blank email to everyone.
I didn't update sarissa.  I just downloaded, Since I've never heard of
sarissa, do I install the update on the server on will that need to be
installed on the users computers?
I'm guessing the server so this email is probably worthless but I'm
tired and lost.
Thanks, Jackie.
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Wednesday, December 19, 2007 8:34 AM
To: mapguide-users at lists.osgeo.org
Did you upgrade the version of sarissa as also specified in that ticket?
- Jackie
ctallman wrote:
> I made the change and it didn't seem to help.  When the site is
> trusted the point features still cannot be selected.
> Chris
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Tuesday, December 18, 2007 5:58 PM
> Subject: Re: [mapguide-users] Trusted Sites
> I think the problem here is that the current AJAX viewer uses the
> Microsoft.XMLHTTP ActiveX object when sending off AJAX requests (if
> your browser is IE)
> More info here.
> http://trac.osgeo.org/mapguide/ticket/368
> - Jackie
> ctallman wrote:
>> I'm hoping i'm just missing something but when I add my mapguide site
>> to the trusted site list I no longer get tool tips and I can't select
>> point features.  If I remove the site from the trusted list I can
>> select the feature again.
>> So I know don't make the site trusted, however we have a site that is
>> running on a https secure address, so its nice to have it in the
>> trusted list.  Plus if its not in the list I get asked the following.
>> This website wants to run the following add-on: 'MSXML 5.0' from
>> 'Microsoft Corporatioin'. If you trust the website and the add-on and
>> want to allow it to run, click here...
>> So I do it reloads and I get the same thing.  However if I make the
>> site trusted I don't get this.  Also If I don't have this MSXML
>> enabled I don't get my pictures next to the legend labels.  I see
>> question marks until I zoom in or make the map refresh.  If I have
>> the
>> site trusted I don't have any of these problems I just can't select
> features.
>> So do I have something set wrong someplace does anyone else see this
>> same problem, can anyone else reproduce this?  I can reproduce on my
>> system.  I've tried it on more then one IE 7.0 computers.
>> I'm using AJAX
>> MGOS 1.2
>> .NET
>> IIS V6.0
>> Windows 2003
>> Chris Tallman
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Trusted-Sites-tp14401044s16610p14407685.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://www.nabble.com/Trusted-Sites-tp14401044s16610p14416885.html
