[mapguide-users] search error: "Identity property type notsupported yet (8)"
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Dec 20 14:51:04 EST 2007
Is the primary key a double?
Try using a single integer column as the primary key.
Regards, Kenneth, GEOGRAF A/S
Michael L. skrev:
> Hi,
> I will test the Unicode issue tomorrow. I already informed Autodesk about
> this problem, but still got no reply. I'm under time pressure setting up a
> working GIS so this forum is really helpful for me. After I posted this
> error message I found on Jason Birch's homepage a sample query "MapGuide
> Open Source / Enterprise GT - Test Application". This code sample is
> fantastic. The query works without any problems in combination with Oracle
> 10g. So I'm able to search my data. Thanks a lot Jason for this code.
> Michael
> JasonBirch wrote:
>> Hi Michael,
>> When you're using MapGuide Enterprise, you're also using the proprietary
>> Oracle provider, so others who are not using Enterprise can't help.
>> Have you tried the open source SL-King Oracle provider?  Lots of people
>> are using this sucessfully with Oracle.
>> http://www.sl-king.com/fdooracle/fdooracle.html
>> It might still be a MapGuide problem though (I have no idea what type 8
>> would be... what SQL type is your identity column?).
>> Regardless, you may also want to submit a problem report under your
>> Autodesk subscription.
>> Jason
>> -----Original Message-----
>> From: Michael L.
>> Subject: [mapguide-users] search error: "Identity property type
>> I'm working with MapGuide Enterprise and Studio 2008 German Edition in
>> combination with Oracle 10g. Everytime I try to use the MapGuide
>> internal search function I get this Error: "Identity property type not
>> supported yet (8)" or "No Matches".
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071220/8090ec32/attachment.html
