[mapguide-users] MG 2.0 BETA...question about Digitizing & Redlining - easy change shape.
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Dec 21 13:01:14 EST 2007
I have not seen any functionality of that kind.
There is the selection, digitizing and editing of an object in
OpenLayers / Fusion.
I have not seen any function that can save this back into the server.
It is fairly easy, as the edited object can be extracted into WKT, which
can be used to update the featuresource.
It does require some coding though.
Regards, Kenneth, GEOGRAF A/S
Maciej Skorczewski skrev:
> ok one more time - i try clear up what i mean...
> i can make Redlining, i know how to draw a line/polygon,point and then
> save it into database...that i easy to do...
> BUT question is: are the in new MG 2.0 any function to fast/flexible
> editing any shape...user sould simply clik on ex. plygon. and easy
> change shape of it....the clik save....
> can anybody tell me is it posible in new MG 2.0
> BradM pisze:
>> Hi, have you tried  editing using sdf3 format and then when you are
>> finished,  convert or save your file as a shapefile?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
