[mapguide-users] MapGuide 1.2 login error
Jason Birch Jason.Birch at nanaimo.ca
Thu Dec 27 00:14:42 EST 2007
No, it's definitely not in the 1.2 release.  That submission was made in November.
Jason
From: mapguide-users-bounces at lists.osgeo.org on behalf of uXuf
Sent: Wed 2007-12-26 3:05 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] MapGuide 1.2 login error
Hi Jason,
Last night I got exactly the same bug as specified in the changeset, i.e.
Web Extensions cannot connect to Server when machine is disconnected from
network. Earlier what I was getting was a side-effect of the above problem.
It's still happening at my end. If it's fixed then it's not reflected in the
1.2 release.
uXuf
JasonBirch wrote:
> I think that it may have already been fixed in the 1.2.x branch.
> http://trac.osgeo.org/mapguide/changeset/2509
> I can't find where/if this change got applied to current 2.0.x trunk...
> Jason
> -----Original Message-----
> From: uXuf
> Subject: Re: [mapguide-users] MapGuide 1.2 login error
> Okay so the real culprit appears to be the Wireless Access Point
> assigning "new" IP address to the system whenever it comes out of
> stand-by. It seems that MG 1.2 picks up the actual IP address of the
> system when it initializes the service on system boot-up, while MG 1.1
> used localhost (or 127.0.0.1) all along. So with 1.2 whenever the system
> gets a new IP, the service refuses to connect.
> Figures that Studio connects through all this mess, because I usually
> use localhost as the server to connect to.
> Couldn't really see that this would get fixed anytime soon, but really
> hope that it does because as far as I see it would be a rather simple
> fix.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/MapGuide-1.2-login-error-tp14398948s16610p14501291.html
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071226/1c87d721/attachment.bin
