[mapguide-users] FW: Problems while labeling polylines
azpublic azpublic at bluewin.ch
Fri Dec 28 10:51:49 EST 2007
uXuf
If you look at the region of my attachment in google maps (Geneva
Switzerland) you can notice on smaller streets that the name does go upside
down. But its quite rare and certainly not as frequent as in mapguide.
Moreover the size of the font is relatively constant from one street to
another ...
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of uXuf
Sent: vendredi, 28. décembre 2007 15:16
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] FW: Problems while labeling polylines
I wouldn't count it as exactly a "bug". I think it is a reasonable behaviour
for that it attempts to display as many line labels as possible. These are
only obscured by the presence of other objects in close vicinity, or the
length of the line, which makes the labels smaller and/or force them to take
the direction the line is taking.
Similar behaviour is seen in Google Maps etc.
uXuf
azpublic wrote:
> Hi again,
> I’m having some trouble correctly labeling some street level polylines. I
> get some upside down labels or sometimes the labels don’t have the same
> size
> as other for no apparent reason
> I included a screenshot of my generated map.
> You will see that some labels start correctly and end up upside down. Some
> other are much bigger than others
 etc ..
> How is it possible to avoid that?
> For example fix the size of the font and also fix the position of the
> label
> to the exact center of the polyline
> Thanks for your help !
> No virus found in this outgoing message.
> Checked by AVG Free Edition.
> Version: 7.5.516 / Virus Database: 269.17.11 - Release Date: 27.12.2007
> 00:00
> 00:00
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/FW%3A-Problems-while-labeling-polylines-tp14525210s166
10p14526292.html
No virus found in this incoming message.
00:00
00:00
