[mapguide-users] Reload layer who are stored indatabase...afteradd new polygons.
Maciej Skorczewski maciej.skorczewski at procad.pl
Tue Feb 6 11:31:55 EST 2007
hi Traian !
how can i make it (clear the tile cache) in ajax viever whit tiled base
layer? How to load it again whit new (updated datasource in postgis
database)
ps. when i try this on vector (no use of tiled base layer) i get this
same result but - alter zoom in, and zoom out ,new object was added to
map. But still problem whit reload layer in actualy view (zoom scale) (i
can make only on-off visibility of layer to see results but this is not
nice solution) .I use tiled base layer becuse it is much faster...
maciek
Traian Stanev napisał(a):
> Is your layer on a tiled base layer? The tiles that got generated for it
> originally are not refreshed if the underlying data changes, since there
> is no way for Mapguide to know that you updated the PostGIS database.
> You will need to add a step to clear the tile cache for the layer that
> was modified.
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
> Skorczewski
> Sent: Tuesday, February 06, 2007 9:30 AM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Reload layer who are stored in
> Hi!
> I store my layer in PostGis database, after add some new polygon to this
> layer i insert to database new polygon (all is ok , whitout problem)
> ...but after that i can't reload layer - so user can't see what he add.
> i use Ajax Viever whit Base layer and when i click zoom to view (who are
> not cache by viewer) i see new object , but after zoom back it
> disappear.
> I use Reload() but it not working.
> How can i reload,or refresh this layer?
> I use:
> MG 1.1.0
> Ajax Viewer whit Base Layers
> PostGIS in PostgreSQL 8.2
> maciek
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
