[mapguide-users] Hiding points on a layer
Hidekazu Shimaji hshimaji at ybb.ne.jp
Thu Feb 8 07:49:13 EST 2007
Hello,
You can use Session Repository to create a layer resource for each user.
This needs Web Extensions API programing.
And you can use [Theme] to hide points with filter conditions.
It is a setting of a layer resource.
The theme has rules, and each rule has a condition and a point style.
If you edit the point style and turn [Style a point symbol] checkbox unchecked,
then points will be hidden with the rule's condition.
Hidekazu Shimaji
--- kalpesh <kalpesh at pie-solution.com> wrote:
> Can points be hidden on a layer based on a criteria specified on the feature
> data of the layer ? So if there are 20 points on a layer, and I want to show
> only a few based on the user logged in (only for a particular session),
> would that be possible ?
> http://www.nabble.com/Hiding-points-on-a-layer-tf3191279s16610.html#a8859286
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
